How Do I Know If I Have A 1275 Engine
12 replies to this topic
#1 Madmurphy
Madmurphy
    Starting My Mini Up
  • 3 posts
Posted 12 June 2014 - 08:49 PM
Hi everyone
I have just bought a 91 cooper but the engine has no id plate on it, would there be  any other id numbers on the engine to say what it is
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 June 2014 - 08:51 PM
I think that the 1275 lumps had no removable inspection plates on the back where the pushrods pass through but i'm by no means an expert so i would wait for someone to clarify
Ben
#3 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 12 June 2014 - 08:53 PM
Type your engine number
http://www.guess-wor...Tech/engine.htm
#4 SuperDeLuxeNick
SuperDeLuxeNick
  • 625 posts
  • Local Club: West Country Minis
it'll be faster than a 998.
#5 Madmurphy
Madmurphy
    Starting My Mini Up
  • 3 posts
Posted 12 June 2014 - 08:57 PM
Thanks Ben I will have a look,
#6 dennismini93
dennismini93
  • 1,093 posts
  • Local Club: nsmoc
Posted 12 June 2014 - 09:17 PM
does it look like it was originally red?
#7 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 12 June 2014 - 11:31 PM
This may also help
http://www.minimania...gine-Power_Unit
#8 roofless
roofless
    Sticker Pimp
  • 7,216 posts
  • Local Club: central minis
Posted 12 June 2014 - 11:36 PM
simple route to follow..... is it injection ?
yes......you got yourself a 1275cc mini
no..... im stumped....and nothing else clever to say..... but Im pretty sure its a 1275
hope it helps :)
#9 Yoda
Yoda
  • 1,958 posts
Posted 13 June 2014 - 06:11 AM
I think the 91 would be a mainstream cooper on carbed, so not injection. Whip the rocker cover off and give us the casting number off the head. 12G940 will be 1275 in most cases unless it is a modded 998 of course.
#10 grahama
grahama
  • 2,442 posts
Posted 13 June 2014 - 06:49 AM
Also if it has two core plugs on the clutch side of the engine block it's probably a 1275,  a breather on the timing chain cover on the fan side of the engine, no inspection chambers on the rear of engine are all good signs but number is the best id
#11 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 13 June 2014 - 07:08 AM
Look down the back of the engine, under the exhaust manifold.  If there's a pair of rectangular plates on there, it is a 998 (or an early 1275....which is really unlikely).
Is there a reason you suspect it's not a 1275?  The ID plate may have been removed if the engine has been reconditioned.
#12 Madmurphy
Madmurphy
    Starting My Mini Up
  • 3 posts
Posted 16 June 2014 - 08:52 PM
still haven't had a chance to check im working away from home, I think it might possibly have been reconditioned.  a lot of good points to check out thanks guys
#13 Cooperman
  • 23,513 posts
Posted 16 June 2014 - 08:58 PM
Look down the back of the engine behind the inlet/exhaust manifolds.
If it has two rectangular cover plates about 7" long by 3" high fitted side by side, then it is a 998 engine (or an early Cooper 997, Cooper 'S' 1071, 1275 or 970, but that's unlikely). If the rear of the block has no such apertures it is a 1275 non-Cooper 'S' engine.
