Edited by Benwrdn, 16 June 2014 - 08:21 PM.
Fitting Type 3 Brake Master Cylinder
Posted 16 June 2014 - 08:19 PM
Posted 16 June 2014 - 08:20 PM
Theres no pics!
Posted 16 June 2014 - 08:22 PM
having trouble with the pics, ill get there !
Posted 16 June 2014 - 08:28 PM
Can't link the photos so had to link the album they are in. Sorry guys
Edited by Benwrdn, 16 June 2014 - 08:36 PM.
Posted 16 June 2014 - 09:38 PM
Is it the yellow tag master cylinder?
If it is, the ports have been reversed from the earlier type, the bottom union(12 mm) goes to the rear brakes, which is the right hand side if looking from front, and the top union(10mm) goes to the front, left hand side looking from front.
Posted 16 June 2014 - 10:02 PM
now I have seen the pictures, it's a bit easier, you are replacing like for like, so the pipes should go bottom of m/cylinder to right of prv(rear brakes), and top of m/cylinder to l/hand side of prv(front brakes)
I have looked at one of your first pictures in your rebuild thread, and that is how it was previously piped up, so it was correct.
Posted 17 June 2014 - 09:13 AM
Here's a diagram courtesy of Minimania to confirm how your pipes should be connected: http://goo.gl/JsNcvZ
I did a wonderful pipe bending job which looked absolutely perfect with lovely bends and spot on angles, until I took a second look and realised I'd got them the wrong way round...
