Can you buy bulb holders for the centre clock? Or bulb holders that will fit? thanks
Center Clock Bulb Holders
Steve-O 2014
, Jun 17 2014 06:55 AM
2 replies to this topic
Posted 17 June 2014 - 06:55 AM
Posted 17 June 2014 - 08:47 AM
By 'centre clock, are you referring to the centre mounted speedo/ instrument cluster? If so, I've recently used these: http://goo.gl/Cv5NTO
Posted 17 June 2014 - 11:48 AM
Yes you can, I've just bought some from Somerfords. There are two types, ones that connect -ve via the body and others where both inputs are isolated (required for oil pressure and ignition tell-tale/warning lights). If you can only get one, get the later as it can be used for anything (and it's easy enough to attached a -ve wire to the clock body).
