Hi all
New on here and hoping for some ideas around a poor running MPI.
Have had a search but not found anything to give me teh fix I'm looking for.
1998 MPI
Ign on, fuel pump primes.
Engine starts OK.
Seems a bit rough at idle but smooths a bit out as it warms up.
Problem is than when one blips the throttle, either medium or fast the engine gasps - feels like lack of fuel. (bit like a weber with failed acceleration pump, if you know what I mean). When throttle blipped quickly it feels as engine about to stall as the revs pick up so poorly.
When raising revs slowly, fuel supplier seems to keep up and it can reach rev limiter (6200rpm)
On the road when pulling away very gently it is ok but as soon as there is any fuel demand (opening the throttle) it gets very little performance and barely accelerates. upshift into 2nd and same effect.
Have fitted new fuel pump, fuel pressure regulator and fuel filter. These did not seem to make any difference to the issue.
All sensors plugged in.
Coolant temp sensor resistance changes with temperature
So does Inlet manifold temp sensor.
Idle Control valve is doing its job and controls idle revs accoding to various loads, eg headlamps being switched on. Also manages revs so as to catch engine as it drops back to idle from raised rpm.
Throttle is correctly closed at idle (no residual tension in cable)
Tappet clearance set to 0.014" across all valves
New plugs correctly gapped
Compressions 175-180 psi on all cyls.
New coolant. No boiling or ejection of coolant
5 litres of fresh fuel in tank
Had car at MoT test garage.
Basic idle test
CO 1.3% (Not OK)
Lambda 1.2 - 1.4 (not OK)
HC 170 - 200 (OK)
Fast idle test 2500 rpm
similar
Any ideas appreciated!!!
Have I missed something obvious?
What other sensors can I check using volt or ohm meter?
Heeeeeeeeelp! :)
Peter
