Suspension Dropped
9 replies to this topic
#1 armstrong95
armstrong95
    Just On Tickover
  • 7 posts
Posted 19 June 2014 - 09:19 PM
1990 mini checkmate was driving down the road today and noticed if I turn slightly right there was a scraping noise turns out the car is now sitting low on one side and the wheel is slightly forward any ideas?
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 19 June 2014 - 09:54 PM
the rubber suspension cones sag with age and the knuckle joint eventually wears through the plastic cup it sits in
#3 Ethel
  • 26,580 posts
Posted 19 June 2014 - 11:45 PM
Compare left to right: gap between top arm & bump stops, the shape of the rubber covers on the lower end of the trumpets, the shape of the rubber suspension cones, any free play in the ball joints or tie rods....
#4 armstrong95
armstrong95
    Just On Tickover
  • 7 posts
Posted 20 June 2014 - 07:12 AM
Oh I forgot to mention it knocks if you grab the wheel and wobble it its todays job just wanted to narrow down what to look for before I start
#5 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 20 June 2014 - 01:26 PM
That could be the ball joints or a wheel bearing. It sounds to me like you need to have a thorough inspection of all of the components as well as the rubber doughnut. You will need a cone compressor to remove it along with taking off the top arm.
Change both front doughnuts as a pair though.
#6 armstrong95
armstrong95
    Just On Tickover
  • 7 posts
Posted 24 June 2014 - 09:43 PM
Well ive changed a track rod solved the knocking and cone and knucjle joint fixed it for a day and now im back to square one still sat too low on the same front corner any ideas ?
#7 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 24 June 2014 - 10:05 PM
with new suspension cones they normally ride very high
#8 armstrong95
armstrong95
    Just On Tickover
  • 7 posts
Posted 24 June 2014 - 10:09 PM
Its still very low ive run out of ideas ?
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 25 June 2014 - 06:47 AM
has anyone cut the alloy trumpet in the past ?
#10 armstrong95
armstrong95
    Just On Tickover
  • 7 posts
Posted 25 June 2014 - 09:06 AM
Not that I can see would it still have the lip if they had ?
