Headlights Don't Work
6 replies to this topic
#1 msackson
msackson
    Starting My Mini Up
  • 2 posts
Posted 19 June 2014 - 10:28 PM
I just took delivery of a 1975 Mini 1000. The headlights will not come on. The high beam switch turns the high beams on, but does not keep them on. I  have to hold the switch. I do not drive it at night, right now.
I'm a newbie - any advice?
Thanks.
#2 Gremlin
Gremlin
  • 2,142 posts
Posted 19 June 2014 - 11:16 PM
Do the sidelights work? Check the switch, just pull it out of the dash and unplug the connector and test the switch for continuity in the various positions
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 19 June 2014 - 11:33 PM
Do you have a multimeter to check if the problem is inside the switch, I assume your holding the flash on for main beam, which confirms the main beam circuit is intact. Check the Blue/white for main beam and Blue/red for dip at the connector at the base of the switch wiring at the base of the column cowling, if you have voltage into the dip switch from the headlight switch then it points towards defective contacts inside the switch assy.
Edited by KernowCooper, 19 June 2014 - 11:35 PM.
#4 Gadgets
Gadgets
  • 471 posts
Posted 20 June 2014 - 06:56 AM
Check the black earth cable behind the middle of the front grille. it has 3 small black bullet connectors, probably need terminals cleaning, I would also clean all the connections there #(side, dip, main, indicators, earth at that location at same time) sounds like something simple to fix! Enjoy your Mini.
#5 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 20 June 2014 - 11:42 AM
High beam is OK.
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 June 2014 - 01:57 PM
I suspect its inside the switch, from the description given
#7 msackson
msackson
    Starting My Mini Up
  • 2 posts
Posted 20 June 2014 - 08:34 PM
Thank you to all who offered assistance. I checked the switch, made sure all the connections were tight, and my lights worked!
Now I have to figure out why the tachometer doesn't work.....
Edited by msackson, 20 June 2014 - 08:35 PM.
