Electrical Spade For Radiator ?
6 replies to this topic
#1 Redjohnno
Redjohnno
  • 190 posts
Posted 20 June 2014 - 03:19 PM
Don't even know if they are called that, but looking to get 2xreplacement for the bottom of the radiator. Had a look, but haven't yet found ones that look like my old ones. Halfords be the place to go, or any electrical specialist? And just making sure thats what they are called! :lol:
#2 cal844
cal844
  • 9,631 posts
  • Local Club: TFMOC
Posted 20 June 2014 - 03:34 PM
Female spades,  i use these,
http://www.ebay.co.u...=item5af9498994
I've changed them all on my mini, including the fusebox, its easy, first you cut the wire as near to the old connector as possible
Then trim the insulation off about 12mm from the end, then crimp the new connector on!!( i use a pair of snips/ side cutters
Edited by cal844, 20 June 2014 - 03:55 PM.
#3 FlyingScot
FlyingScot
  • 2,664 posts
Posted 20 June 2014 - 06:52 PM
Take the old one with you to Halfords or B&Q or a local auto factors if you only need a couple.
The switch at the bottom of the radiator on an SPi can be tricky as often the cable itself is corroded/rotten inside.
Better to use a proper crimp tool - B&Q do a set including a decent tool.
FS
#4 Redjohnno
Redjohnno
  • 190 posts
Posted 20 June 2014 - 07:07 PM
Thanks chaps. You are spot on FS, The cable on one of them has snapped off, with the end of the it inside the connector.
#5 Redjohnno
Redjohnno
  • 190 posts
Posted 21 June 2014 - 09:04 AM
Forgot to ask you guys what wire (Green & Black) goes into which side of the sensor??
#6 xrocketengineer
xrocketengineer
    Rocket Man
  • 1,637 posts
Posted 21 June 2014 - 01:18 PM
It does not matter.
#7 Redjohnno
Redjohnno
  • 190 posts
Posted 21 June 2014 - 01:24 PM
