hi, anyone know what replacement points & condenser i can use for an aldon 100AY? (no vac advance)
cheers,
bear.
Posted 20 June 2014 - 08:33 PM
cheers,
bear.
Posted 20 June 2014 - 09:13 PM
Same fitment as the 45D as far as I know. I have the Aldon Ignitor in mine
Posted 22 June 2014 - 08:22 AM
cheers pal.
Posted 22 June 2014 - 11:00 AM
Posted 23 June 2014 - 11:38 PM
Brad, why not upgrade to electrnic ignition??
thought about it but i have a ballast ignition wire so i would have to replace it?
Posted 23 June 2014 - 11:54 PM
No you could keep the ballasted ignition and run a new12v switched feed to the igniter red wire which would connect direct and the red is not on the coil + like a 12v system.
I would convert to a 12v system and get rid of the ballasted wire which causes lots of wiring loom damage when it burns out. Done lots its a major job, people think it wont happen to me ?
Posted 24 June 2014 - 09:38 AM
When our 998 was swapped, we disconnected the resistor(Pink /white on Brads car) at both ends, then used crimp spade connectors to use the P/W, W connection for the new trigger wire, now we always have the old system available incase of problems
