here is my latest acquisition, although this isn't technically true as its been sat in our garage for the last 7 years, but it was my mums and is now mine (i think)
anyways i got it down the lockup to see what i could see. my dad started doing a few bits to it but ran out of time and space so its mainly stripped with the odd patch carried out.
list of things so far to do :
Boot hinges
boot repair panel needs grinding down and re-welding (ran out of gas when welding and looks a mess) also needs battery box but i may be able to patch this.
rear quarters need a patch or suchlike at the bottom of the seam and just a general once over check for rust/filler.
inner sills + passenger side floor patch, both front flinch panels.
passenger door needs either re-skin or a patch weld at bottom of the door.
drivers door is totally gone at the bottom, i may be able to repair it but its looking like a new door to me.
the usual a panels and scuttle.
new bonnet
that's the welding/bodywork side so far, i'll worry about the interior & engine at a later date.
NEVER done bodywork before other than a bit of filler so this is going to be a big learning curve for me in terms of preparation and welding. i took a welding course the other month so i know the gist of what i'm doing but i can see me going through a lot of practice pieces before i take the welder to the car and i'll start in the boot so its not so noticeable if it goes wrong.
ill add decent pictures later in the week but for now my phone ones will have to do.
