Pulling To Left Under Braking
Posted 22 June 2014 - 07:55 PM
I know my tie bars are slightly bent, which I plan to replace in the next few weeks. No idea what they do or if they would affect braking though!
My brake pads look ok.
Posted 22 June 2014 - 08:02 PM
Posted 22 June 2014 - 08:08 PM
I would say that you have imbalanced brakes.........
Posted 22 June 2014 - 08:22 PM
Which could be a sticky piston, or the pad is down to the metal
Posted 18 August 2014 - 12:51 PM
Hi,
I changed my brake discs and pads only a few months ago, and theyve warped again (the juddering's back when I brake), and i also have a pull to the left when I brake. I've come to the conclusion that is must be a sticky piston.
Can I repair this or do I need a new caliper?
Cheers (Sorry to hijack)
Posted 18 August 2014 - 01:49 PM
its worth checking your tyre pressures too. just had two new front tyres fitted and the tracking done at the same time. the next day it felt like it was pulling to the left a bit. I naturally assumed the tracking was still slightly out until the day after when I came to it and the front n/s tyre was totally flat. still haven't taken it back in either!
