Best Oil For Mighty Mini
9 replies to this topic
#1 charliebudd
charliebudd
  • 429 posts
Posted 23 June 2014 - 11:06 AM
I am currently using mobil 0w40, this has proven to give us 2 bhp on the rollers..
i am now looking for an alternative , i have been recommended this  http://www.opieoils....engine-oil.aspx
any opinions or other options?
#2 Cooperman
  • 23,513 posts
Posted 23 June 2014 - 02:29 PM
Always a difficult choice for true competition Minis.
The thinner oils will give a bit more bhp, but at the expense of gearbox and engine bearing life.
With race engines and transmissions being re-built very often, it is OK to use a thinner oil and accept the longer term issues which happen when thin synthetic oils are used in road and rally cars.
#3 casper2300
casper2300
    Starting My Mini Up
  • 2 posts
Posted 24 June 2014 - 03:21 AM
Hi I tend to use the millers mini oil I find milers to be of good quality. I normally use these guys
 http://www.bmfautopa...ccessories.aspx
Find them to be cheaper and great service too.
Hope this helps
#4 Cooperman
  • 23,513 posts
Posted 24 June 2014 - 11:13 AM
The oil recommended for road & rally Minis is a quality 20w50 with Valvoline VR1 coming out as favourite. In fact, probably the ultimate oil for a Mini is Kendall 20w50, but that's NLA in the UK.
However, for racing the thicker oil increases drag within the engine which loses a couple of bhp and a thin synthetic oil will undoubtedly give a little bit more power and, maybe, save a few 1/10ths of a second per lap.
But racing engines are rebuilt very often, after just a few races, and cost is not the critical factor, it is out-and-our performance, so the long-term problems of an ultra-thin oil in an old design A-series engine is not an issue.
Another way of getting a little bit more power is to adjust the oil pressure down to reduce the power consumed by the oil pump. So long as the engine is rebuilt after every 3 or 4 races and the oil changed after every race that gives a tiny bit more.
I once tried a fully synthetic 5w30 in a rally Cooper 'S' and it cost me a full engine & gearbox rebuilt - very expensive lesson!
#5 Scoop77
Scoop77
  • 508 posts
Posted 24 June 2014 - 09:45 PM
Top speed automotive do the valvoline and the Kendall. How many litres is in an American gallon?
#6 AlexMozza
AlexMozza
  • 1,248 posts
  • Local Club: Not Yet
Posted 24 June 2014 - 10:03 PM
Valvoline VR1 20w/50 Best oil for racing.
#7 Cooperman
  • 23,513 posts
Posted 24 June 2014 - 11:21 PM
Actually Kendall 20w50 is the absolute best, but it's hard to find and very expensive. I used it for years when a friend of mine was a dealer and I got it easily. Apparently it is made from Pennsylvania crude oil which is the finest you can get.
But Valvoline VR1 is also excellent and is what I use now..
#8 Scoop77
Scoop77
  • 508 posts
Posted 25 June 2014 - 05:59 AM
It's 3.758 litres. Which does make the Kendall expensive!
#9 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 25 June 2014 - 06:50 AM
Yes considering we would need 2 tins per service!
#10 Scoop77
Scoop77
  • 508 posts
Posted 26 June 2014 - 05:25 AM
Yeah Valvoline it is ;)
