For sale, http://www.ebay.co.u...#ht_3730wt_1275
£6500 ono
Highly modified/custom mini Complete nut and bolt rebuild in 2011 by myself
Magazine featured last year(will come with car)
Most if not all receipts since build have been kept, over £20,000 spent Grabs attention where-ever it goes, Never been pulled over by the police for random stops since owning the car.
Won 1st place at Malvern last year under custom/modified class.
Very reluctant sale but space is an issue due to losing my garage and change of working hours means less time to spend on it.
I have owned this car since 2009 and used it as a daily driver for the last year. It puts a smile on my face everytime I use it! The car will come with all paperwork I have, the receipts, magazine feature, pictures of the build and photos from appearances in other mags. It will also include all the info I have collected regarding part numbers as it has a collaboration of many parts...fan belts....spark plugs...rotor caps etc so it will be easy for the new owner to identify where to get acess to new parts.
This car is checked over every month mechanically. I have a checklist that I will handover for all fittings on the car that can be carried on by the new owner if they wish...This was purely as a safety precaution and preventive maintenance. The car will come with a spare cam belt/rotor cap/arm/plugs/leads/coil/fuel pump/gear lingake spares/ball joint/spacer adapters/wheel nuts/innertubes and many more. These were always kept in the car for potential breakdowns.
Please note...although this can be/is used as a daily driver, it only has the bare minimum to make it road legal...this was built purely for the track at the time (this has only every seen santa pod dragway once!)
It had a new engine fitted last year...a later spec with 44,000miles. All stripped and cleaned/new belt fitted (I have pictures that show condition of engine during the build)
It also handles great unlike some Vauxhall conversions but has never been set up professionally...I have never found the need to.
The car was last weighed at 580Kg with paperwork to confirm.
This was rolling roaded at 120bhp at the wheels last year but has since had a new race head/fuel pump/adjustable vernier /exhaust and manifold fitted. The car is running rich and isn’t great on fuel...I have ran it like this since owning it. This can be set up to achieve a better mpg but the initial cost I have never got round to funding.
Insurance for me 24 at the time 6 points and all mod’s declared £ 1000 per year I want to sell this to a mini enthusiast to give the car the best possible chance of not being rolled on the first corner by a boy racer! This car has become part of the family and has memories attached to it so I would like to sell it knowing that it’s likely to be looked after.
Modifications
Engine/Gearbox/cooling ·
- X16SZR 1600cc Vauxhall 8v 120bhp ATW 45,000 miles ·
- Blydenstein Race Head ·
- Sports Injection Kent cam NV062 ·
- Adjustable Kent vernier Pulley ·
- Kawasaki KeihinnCVK Ninja Carbs and pipercross filter/backplate ·
- Brogg Bros manifold ·
- Cavalier 1.2 Electronic Ignition setup ·
- Ashley 4-1 Exhaust system(modified) with no CAT · Cherry bomb straight through exhaust 2’’
- Nipppon Denso Alternator ·
- Metro Radiator with powerfull 10’’ cooling Fan (controlled by a toggle switch) ·
- Alloy oil catch tank ·
- Silicone water hoses/Nova expansion tank ·
- Allspeed one peice billet driveshafts 22 spline ·
- Corsa modified gear linkage adjustable ·
- Tigra gear selector ·
- Inner 22 spline pot joints ·
- Outer mini CV joints ·
- F13 5 speed wide ratio corsa gearbox f13w374 ·
- Hydraulic Clutch conversion for gearbox ·
- Alloy racing fabrications fuel tank 6 gallon baffled ·
- Sytec fuel pressure regulator set at 3 bar ·
- Facet cube fuel pump/filter
Body mods
- New front floor pans 2011 ·
- New drivers side rear floor pan 2011 ·
- Tubbed/reinforced arches 2011 ·
- Rollcage floor plates/mounts ·
- Miglia style bulkhead
- Lower bulk head box for gear selector clearance ·
- Gear selector raising bracket fitted ·
- Roof and dash rails cut out ·
- Coilover reinforcement plates fitted ·
- New door steps 2011 ·
- New lower scuttle 2011 ·
- New rear light panels 2011
- New rear quarter 2011
- Bins and benches cut out 2011 ·
- Inner wings cut off ·
- Roof cut out ·
- Carbon roofskin ·
- Carbon roof vent/Subaru ·
- Carbon look wingmirrors ·
- Carbon wide miglia arches ·
- Carbon cooper s stlye bonnet ·
- Carbon bumper and overiders ·
- Carbon bootlid ·
- Carbon rear valance ·
- Carbon fibre parcel shelf ·
- Carbon door cards ·
- Fibreglass removable front with a panels attached ·
- Fibreglass passenger door ·
- Rear diffuser ·
- Fibreglass boot floor ·
- Polycarbonate windows (front and drivers as normal) ·
- OMP 6 point cage with additional removable rear diagonal/dash and door bars. ·
- Jon Betts harness bar
Suspernsion/Frame/Brakes ·
- Front Gaz coilovers with 500lb 7” springs ·
- Allspeed powdercoated front subframe ·
- Rose jointed bottom arms and tie bars 2011 ·
- Rebuilt standard top arms 2011 ·
- 8.4 Vented/grooved discs ·
- 8.4 4pot alloy minisport callipers ·
- 1.25’’ spacers on front/back ·
- Race track rod end/extended ·
- Modified powdercoated rear TDK beam ·
- Rebuilt standard radius arms with lugs grinded off 2011 ·
- Billet handbrake quadrants ·
- Kad rear disc conversion/ebc pads/billet hubs ·
- Protech offset coilovers 175lbs 8’’springs ·
- Quick steering rack ·
- 7x10 mini special splitrims black ·
- Falken tyres FK07E ·
- Rear negative camber brackets
Interior
- Custom drivers Recaro Pro SPG fibreglass seat ·
- Magnum matching passenger seat ·
- Luke harness(drivers) No passengers ·
- Omp helmet hook ·
- Lifeline plumbed in fire extinguisher and nozzles located around footwell/engine bay ·
- No carpets/sound deadening ·
- Lightweight door furniture ·
- 2x hand extinguishers ·
- OMP seat sidemounts ·
- Modified handbrake ·
- Custom dash and toggle switches ·
- ETB digidashes ·
- Complete rewire with relays etc 2011 ·
- ETB digidash ·
- Quick release snap off steering wheel and Momo boss ·
- Modified lightened steering column and stalks ·
- Black Cage padding ·
- Pull cables for power supply and extinguisher located on scuttle (locked for daily use) and inside car ·
- Powervamp lightweight battery and tray ·
- Modified drivers footwell for floor mount pedals ·
- Tilton floor mounted pedals with Willwood masters x 3 ·
- Brake bias adjuster (not fitted) ·
- Boot mounted washer bottle ·
- Internal braided fuel lines and battery lines
Exterior ·
- Mist spray jets ·
- HID conversion lights with led day lights ·
- Clear front indicators ·
- Mark 1 carbon wrapped grill ·
- Lightweight bonnet pins front and back ·
- Polycarbonate windows and slider for passenger window with lock ·
- Smoked rear lenses with built in fog ·
- Led numberplate lights ·
- Decals/graphics ·
- Carbon wrapped headlight rims and rear light cases ·
- T pull cables for power and fire extinguisher (locked) ·
- Aeroblade wipers ·
- Kawaski 104 green paint
Few Bad points
- Drivers door window Mech has broken, works but has to be persuaded(I think I have a spare door and mech that I can give to the buyer) ·
- Paintwork isn’t the best...few imperfections/scratches/chips absolute minimul rust if any...any inspection under and inside car welcome... ·
- Passengers door only opens from inside( I Built it this way but could be seen as a bad point) ·
- Wheel paint could do with freshening up ·
- One scratch on roof and roof vent has a slight bubble in the carbon fibre weave(small) ·
- No seatbelt for passenger seat ·
- Fuel gauge doesn’t ever reach zero(reads in a percent and 3% is empty) It alarms at 5% but can be changed to what ever you like. ·
- Few hairline cracks in some of the fibreglass panels
Quite minimal but please don’t expect a concourse car more of a built for purpose. I have probaly missed some information off(which i will update if I realize!)
please ask for more info/pictures.
The car has tax and MOT and is being used toget me to work...
THE NUMBERPLATE IS NOT INCLUDED (this will be sorted during the sale)
(VIEWING HIGHLY ADVISED, THIS IS NOT A NORMAL MINI)
please mail [email protected] for info more pictures or viewings
(I am contactable anytime through this email). (viewings will not be at my home address due to risk of theft to the vehicle)
