Can You Reuse The Connecting Rod Pin
25 replies to this topic
#16 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 03 July 2014 - 10:06 PM
I can't recall the number sorry.
Ac
#17 tom1
tom1
  • 323 posts
Posted 03 July 2014 - 10:14 PM
Thanks any way . Just broke the top ring !  :ohno:
#18 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 03 July 2014 - 11:06 PM
Honestly, just fit the right pistons, less hassle more reliable.
Ac
#19 tom1
tom1
  • 323 posts
Posted 04 July 2014 - 05:46 AM
It was just  matter of cost and time, a new set of pistons, bore/hone,skim the block for deck height, or turn the pistons down what would you say £375 at best with a cheap set of pistons, and for me I would never build a motor over +0.040. So £15 to get piston machined down seam a good idea at the time. Wish I had build it with a new block and all new parts, isn't that what they call hindsite
        :bah:
#20 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 04 July 2014 - 06:50 AM
The hepolite pistons from the Fiesta weren't that great were they? I think they we're 1100 crossflow ones from memory.
When I started to build one of these I noticed that the gudgeon pin was a little loose in the piston too. I gave up on it in the end and sold it all on. I talked to a few engine builders and their recommendations were pretty much a unanimous "Use 74mm Omegas".
#21 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 04 July 2014 - 06:51 AM
And yeah, hindsight is always 20/20 vision!
#22 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 04 July 2014 - 06:53 AM
And I think when I talked to Calver about this engine, he recommended increasing the size of the head combustion chamber rather than machining the piston crown too. I was looking for 10:1CR for mine so needed big head chambers
#23 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 04 July 2014 - 12:17 PM
It likely won't need a bore for the 74mm pistons. Just honing to get the new size. £200 for pistons £60 for honing?
AC
#24 tom1
tom1
  • 323 posts
Posted 05 July 2014 - 06:52 AM
I have this thing about money. I used to have a job that  paid just under the average pay in the UK, giving me the opportunity to work on my mini. Now I have a job that pays less than the living wage(0 hours contract but have to work 50 every week,all @ a standard rate) due to market forces. In short I have to take a in depth look at what I spend. Here is my costing
£196.8 pistons
£    9.0 postage
£  60.0 honing
£  12.0 fitting pistons to rods
£  15.0 turn pistons down
£  35.0 time of work
£  42.0 running cost of land rover (17 miles x 4 trips)
£369.80
Ok I should of put £370 but £375 sounds better(so sue me). You have got a very good reputation on here and if I lived down your way I would use you and I like your tag line.  :highfive:
#25 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 05 July 2014 - 09:03 AM
No one said building a reliable engine was cheap.
You may just need to wait longer and do it right.
Ac
#26 69k1100
69k1100
  • 376 posts
Posted 05 July 2014 - 09:19 AM
Or tune it for ethanol.
