Rear Wiring Loom Earthing
9 replies to this topic
#1 westlin
westlin
  • 281 posts
Posted 24 June 2014 - 12:38 PM
Can someone advise where the rear loom earth connection connects to the chassis. It was not connected when I got the car so have no clue.
Thanks in advance
#2 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 24 June 2014 - 12:47 PM
What terminal is on the wire? A spade or ring terminal?
#3 westlin
westlin
  • 281 posts
Posted 24 June 2014 - 05:08 PM
Ring terminal
#4 Gremlin
Gremlin
  • 2,142 posts
Posted 24 June 2014 - 05:33 PM
It goes on one of the rear light cluster studs, make sure the stud and nut is clean
#5 westlin
westlin
  • 281 posts
Posted 24 June 2014 - 07:57 PM
Ok thanks
#6 A-Cell
A-Cell
  • 1,610 posts
Posted 24 June 2014 - 08:12 PM
The rear earth point is actually on the floor of the boot on the LH side behind the tank at the back of the boot. Between the tank fixing and the rear lamp.
#7 A-Cell
A-Cell
  • 1,610 posts
Posted 24 June 2014 - 08:13 PM
Earth Points
The following illustration indicates the general position of each Earth Point on the vehicle.
Connector No
Title
Location
C361
Earth eyelet - radio
Behind centre of fascia
C556
Earth eyelet 1
RH side of engine compartment
C557
Earth eyelet 2
Luggage compartment - LH side
C558
Earth eyelet 3
C559
Earth eyelet 4
C560
Earth eyelet 5
C561
Earth eyelet 6
Beneath rear seat
#8 westlin
westlin
  • 281 posts
Posted 25 June 2014 - 12:08 PM
im guessing as the boot floor and the hinge panel have been replaced that may also have gone. Could I use the light bolt or is that not likely to earth.
#9 Yoda
Yoda
  • 1,958 posts
Posted 25 June 2014 - 12:11 PM
If it is the one from the loom close to the lamp then yes, under one of the lamp fixing nuts is standard.
#10 westlin
westlin
  • 281 posts
Posted 25 June 2014 - 02:47 PM
ok thats where I go for then.
