What size is the bolt for the front suspension
5 replies to this topic
#1 murtle
murtle
  • 382 posts
  • Local Club: None :(
Posted 21 June 2006 - 06:26 PM
K i am changing the front suspension but need to know the exact size of the biolt under the bonnet i need to undo as i dont have one the right size so need to buy one but dnt want to buy the wrong one ne ideas?
#2 pikey7
pikey7
  • 3,824 posts
Posted 21 June 2006 - 06:56 PM
you mean the big "tower" bolt on the crossmember holding the subframe in?
( I can check in the garage at half time, but someone may know it off the top of their head! :( )
#3 Leonard
Leonard
  • 784 posts
  • Local Club: mini rebels
Posted 21 June 2006 - 06:57 PM
i THINK it 1 5/16" (1 inch and five sixteenths) better check tho i drink alot of cider
#4 1984mini25
1984mini25
  • 8,786 posts
Posted 21 June 2006 - 07:33 PM
The socket you will need is 1.5/16" Rover Mini, Austin Allegro 1100/1300, Maxi etc hub nuts
but also fits the top tower subframe bolts, and steering wheel nut
#5 murtle
murtle
  • 382 posts
Posted 21 June 2006 - 10:47 PM
i found it, went down halfords and got a couple of sizes and went outside and checked them before i brought it :( it is a 33mm in new money
#6 minislapper
minislapper
  • 1,957 posts
Posted 22 June 2006 - 07:03 AM
There is no exact equivalent between metric and imperial. Buy the right socket from one of the mini spares companies or you will end up damaging the head and/or doing yourself some damage by using the wrong sized socket !
