Engine Rebuild Advice
Posted 24 June 2014 - 10:50 PM
Any help would be greatly appreciated
Thanks Dan
Posted 24 June 2014 - 10:55 PM
Posted 24 June 2014 - 11:04 PM
Posted 25 June 2014 - 03:13 PM
Posted 25 June 2014 - 03:20 PM
You need to strip out the valves, press out the old guides,press in the new ones to a set depth and then ream them to the correct size.
Posted 26 June 2014 - 08:34 AM
and then re-cut the valve seats, if you don't it will prematurely wear your guides if your seats are not centralised to the guide.
Posted 26 June 2014 - 12:44 PM
It depends how worn it is, initially strip it down and measure everything, determine whether honing out the bores and putting in new rings would be acceptable but yes, potentially not a lot of work, would be worth getting valve guides replaced as they're only cheap and it is bound to help with you oil consumption unless done recently (doesn't sound like it)
This .... A 998 at 140K is doing exceptionally well to produce 46 horses - even with a stage 1 kit on so much so that I suspect that its possibly not the original engine or it's previously been rebuilt....first job is to have a good squint at exactly what you've got and go from there.....having said that - if its running sweetly, producing decent 'ish power and not using alarming amounts of oil.........stick with it!
