Is There A Serpentine Belt Conversion
Posted 25 June 2014 - 06:15 AM
Any info would be great thanks
Posted 25 June 2014 - 06:30 AM
Have a look at teh MPI mini set up, that should give you what you are after
Posted 25 June 2014 - 06:33 AM
ive a mpi water pump pulley
Posted 25 June 2014 - 09:56 PM
Posted 26 June 2014 - 05:02 AM
Toothed belt is not to be recommended. You'll need to run quite high tensions to prevent tooth hopping during snap acceleration and you'll need to have every aspect of the drive perfectly aligned - a poly belt is a better option.
Posted 26 June 2014 - 05:43 AM
Posted 26 June 2014 - 05:59 AM
Why are you runing such a big alternator...are you planing on providing power to a small country..
Posted 26 June 2014 - 08:02 AM
Posted 26 June 2014 - 07:39 PM
370A alternator? I think not. You'll not be using chains and sprockets either, least not for very long.
You need the best part of 10HP to drive the thing, certainly easy with a belt...though I'm not sure that the power of the engine will be up to it.
