Need Help With My New Engine Parts.
17 replies to this topic
#1 se_juggles
se_juggles
  • 1,043 posts
Posted 25 June 2014 - 10:58 AM
hi guys.
basically im looking at rebuilding my engine but im not sure what parts will work well together.
i have a 1330 block with sw5-07 cam, vernier duplex timing gear but the rest is pretty standard. I am not looking for the performance as such. more of the reliability with a little bit of performance added.
questions:
1. can i have a 1.5.1 ratio rolling rocker with this as im not sure if a high lift cam and high lift rocker is a bad idea? maybe to much lift??? lol
2. what clutch would you advise along with the housing and flywheel housing etc. pretty much that whole setup.
3.i have a mega jolt system, so which manifold etc do i use.
4. is there a more reliable alternator.
5. do i need a starter motor (maybe a stupid question lol but im a noobie)
6. what pistons would be best to buy (one of the ones i have has a burn on the edge)
7. are electrical cooling fans and an oil cooler worth getting and how do you fit them.
i think that is all. sorry im abit of a noob but we all have to start somewhere. any help would be great.
p.s can you change a car to servo from cylinder setup and vise versa and what one is better?
Thank you SE
#2 se_juggles
se_juggles
  • 1,043 posts
Posted 26 June 2014 - 01:37 AM
any help. im looking at ordering the rolling rockers soon so information on that would be super.
thank you se :)
#3 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 26 June 2014 - 07:21 AM
I'm putting Minispages Mega pistons in my 1330
Not sure the 1,5 rollers give you any extra and may make it worse.
Need more info on the other items like what alternator do you have and what's the problem?
Edited by gazza82, 26 June 2014 - 07:26 PM.
#4 Carlos W
Carlos W
  • 10,115 posts
Posted 26 June 2014 - 07:42 AM
Don't bother with roller rockers, they may give you a couple of bhp right at the top, but you'll lose power lower down.
Instead put your money towards a decent ported and polished head.
Are you going to run megajolt or megasquirt, as megajolt only replaces the distributor
#5 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 26 June 2014 - 07:30 PM
5) yes
7) fans possibly but cooler unlikely on road car
Servo is in addition to master cylinder and you can get separate remote ones. You will also need a vacuum take-off from the inlet manifold
#6 se_juggles
se_juggles
  • 1,043 posts
Posted 27 June 2014 - 11:49 AM
Its megajolt. I was told its better than mega squirt.
I have a ported head. If rolling rockers are not reliable then I wont bother but will the lower ratio ones act the same as the standard. Ive heard there more reliable at preventing some wear and tear....
#7 Carlos W
Carlos W
  • 10,115 posts
Posted 27 June 2014 - 11:56 AM
If it's a megajolt, then you need either a throttle position sensor, or a mass air pressure take off.
You can run any carb and manifold
#8 se_juggles
se_juggles
  • 1,043 posts
Posted 27 June 2014 - 02:08 PM
i didnt think i needed a carb because it comes with a ecu system???
#9 Carlos W
Carlos W
  • 10,115 posts
Posted 27 June 2014 - 02:30 PM
Megajolt, you don't need a distributor, megasquirt, you don't need a carb
#10 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 27 June 2014 - 05:22 PM
... will the lower ratio ones act the same as standard ...
Standard are about 1.2:1, rollers come in 1.3:1. What they will be is more accurate and and wear in the rocker fingers will be corrected.
#11 se_juggles
se_juggles
  • 1,043 posts
Posted 03 July 2014 - 04:56 PM
Ok thank you so getting a 1:3:1 rocker would be bettet.
Can I fit megajolt and megasquirt systems together or is megasquirt just better im sort of confused now as I qas told megajolt was a much better system but carbs are nothing but trouble.
Not been on for a while so abit of a late reply sorry
Se
#12 se_juggles
se_juggles
  • 1,043 posts
Posted 06 July 2014 - 06:30 PM
#13 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 07 July 2014 - 12:19 AM
Megasquirt can do both injectors and ignition circuits. You'd need to get some injectors and a suitable manifold, or just buy a kit similar to this:
http://www.twinkam.c...gement-Kit.html
I'd suggest you do a lot more research into what you want and what is possible before spending any money...
#14 se_juggles
se_juggles
  • 1,043 posts
Posted 05 September 2014 - 04:02 PM
Ok i have been advised to get rid of the megajolt because i want the ignition and fueling system and apparently specialist components or someone like that do a full system which i thought would be alot handier.
so far i think i will go:
1330cc block with my ported head
swiftune sw5 cam with duplex timing chain
lightened flywheel
omega forged pistons.
5-speed gearbox
now all i need to know is can i run a supercharger with the ecu and fueling system without the carb or is there another supercharger i would have to use.
Im so useless at this haha
#15 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 05 September 2014 - 05:02 PM
I cant advise, but would like to know these answers
Everyone must start somewhere!
