Oil Pressure
Posted 25 June 2014 - 01:50 PM
Posted 25 June 2014 - 03:21 PM
What oil pressure do you have at 4000rpm hot?
Posted 25 June 2014 - 03:27 PM
Posted 25 June 2014 - 04:39 PM
What oil is in it? I had a similar prob when I ran mine in with scrappy oil then put Millars and I got better oil pressure still drops to 20psi at island after a long run but I'm.told that's ok
Posted 25 June 2014 - 07:14 PM
Around 65.What oil pressure do you have at 4000rpm hot?
Posted 25 June 2014 - 07:15 PM
Thats what i had in before though and it was a lot worse.If I was you I would put the original spring and plunger back in and see what happens then, said this before the factory fitted 5,000,000 of them and never had a problem, what you have in my humble opinion is a very effective downgrade that goes for the adjustable type and steel ball. If you oil pressures remains low after this your problem maybe elsewhere.
Posted 25 June 2014 - 07:16 PM
Valvoline vr1What oil is in it? I had a similar prob when I ran mine in with scrappy oil then put Millars and I got better oil pressure still drops to 20psi at island after a long run but I'm.told that's ok
Posted 25 June 2014 - 08:48 PM
You said you had the steel ball bearing? this is not the same thing as the plunger. This is the plunger type relief valve.
Edited by Stu1961, 25 June 2014 - 08:56 PM.
Posted 25 June 2014 - 11:21 PM
Touch wood its nothing more serious mate ;-(
Here is a picture of how my engine was this morning after it gave up on me the other week with suspected head gasket failure just 1000mls into its rebuild.
engine block re paint.JPG 79.74K
11 downloads
Its new head has arrived today so im hoping to have it up and running again for the weekend !!
new head 1.JPG 54.67K
8 downloads
Posted 26 June 2014 - 06:46 AM
The oil pressure you state at idle sounds ok. On idle, ours is 65 when cold and 20 when hot. Once on the move the pressure soon goes back up to around 55.
It has been like this for 3 years ( since we have had it ) and gives me no cause for concern.
