Wheel Balancing Weight Adhiesive
ADRay
, Jun 26 2014 02:19 PM
5 replies to this topic
Posted 26 June 2014 - 02:19 PM
One of my wheel weights fell off, luckily it was in my driveway, so I have it.
What should I use to stick it back on? (When I search online it just comes up with new weights)
Thanks.
Thanks.
Posted 26 June 2014 - 02:50 PM
Double sided foam tape.
Do you know exactly where it came off of?
Posted 26 June 2014 - 05:06 PM
Yes, there is still some residue on the wheel.
Posted 26 June 2014 - 05:42 PM
As Harry said, either that or just pop back to your local tyre place and get them to pop another weight on?
Posted 26 June 2014 - 05:58 PM
I tend to put some alu tape over the top of wheel weights to help avoid them becoming unstuck. Not failed for me yet and the same thing is used on a Formula Renault single seater that I work on, again yet to fail.
Posted 26 June 2014 - 06:45 PM
Alex is right, MSA regs for some circuit classes now as well. Also I write on the wheel/tyre the amount of weight added in its position. Should you lose a weight, you can stick it straight back on again.
