Can This Shell Be Saved? (Pic Heavy)
rust repair
15 replies to this topic
#1 MiniThirty89
MiniThirty89
    Just On Tickover
  • Just Joined
  • 6 posts
Posted 26 June 2014 - 03:11 PM
I have a 1993 Mini Cooper which is quite rusty, and I was wondering if anyone thinks it can be repaired?
Here is a picture of the car before:
The car doesn't seem to look that bad in the picture, however underneath was a different story.
Due to electrical problems and burnt wires, the car is now off the road and I have had a chance to look at it properly.
The car now:
So far the rust has been found on the floors, sills, door steps, A panels, boot floor, the boot, front wings, front panel, bonnet, scuttle, flitch, the doors, the bulkhead and probably many more places.
The floor which someone has plated up, along with oversills fitted  :ohno:
There is also a hole in the N/S rear wheel arch:
and below that some more rust inside the rear bin:
The bulkhead is also a little bit rusty:
The scuttle was made of filler and mesh, so that needs replacing:
The drivers side fresh air vent was also a bit rusty:
Whilst the passengers vent looked a little better
Also the O/S rear quarter looks like it'll need a bit of work:
So, what are your thoughts?  :-)
#2 JacckKirk
JacckKirk
  • 889 posts
Posted 26 June 2014 - 03:14 PM
Its saveable but would need a complete restoration project
#3 henri1972
henri1972
  • 277 posts
Posted 26 June 2014 - 03:28 PM
it can be done just be a bit of work look through some of the rebuilds on here to give you some idea
#4 Tomm
Tomm
  • 2,462 posts
Posted 26 June 2014 - 03:31 PM
Most certainly salvageable.
It depends how much time and money you want to invest, and what skills you have and if you are willing to learn and refine the skills you don't have but yes, you sure would be able to save that.
Have a look through the Projects section, some people have saved things that most would dismiss almost instantly.
It sure is possible to get that shell back to its former glory, probably even better!
#5 Colinmac1330
Colinmac1330
  • 261 posts
Posted 26 June 2014 - 03:43 PM
Thats a minter! Seen an awful lot worse than that
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 26 June 2014 - 04:28 PM
It needs a lot of work but is a good starting place.
#7 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 26 June 2014 - 04:30 PM
That can easily be saved! My 93 Cooper shell was in pretty much the same condition as that. It has since been fully repaired and welded and is now in the spraybooth.
#8 minivanman1961
minivanman1961
  • 110 posts
Posted 26 June 2014 - 05:13 PM
PM Sent  :proud:
#9 Marco1972
Marco1972
  • 822 posts
Posted 26 June 2014 - 05:31 PM
As others have said
Well worth saving I've seen much worse !!
#10 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 26 June 2014 - 05:41 PM
Just take your time planning where to go first, then concentrate on that area then move on and so on, I am doing exactly the same at the moment.  Quite downhearting to start with but enjoy it!
#11 1275GTS
1275GTS
  • 668 posts
  • Local Club: bmc
Posted 26 June 2014 - 05:47 PM
Definitely salvageable. My 93 spi was worse and I did all the welding etc myself. If you can do your own welding it won't be to expensive. I used pattern panels including a pattern scuttle and saved a fortune.
#12 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 26 June 2014 - 08:03 PM
Wish was as in as good a condition as yours! If you have your own garage and tools to do welding then no problems, just accept that it'll take a while!
#13 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,068 posts
  • Name: Neil
Posted 26 June 2014 - 08:09 PM
There is a lot of work but very doable. You will have to seriously weight up your capabilities as to what you can do yourself certainly from a welding point of view.
#14 DiscoDarren
DiscoDarren
  • 136 posts
Posted 27 June 2014 - 11:51 AM
It looks in slightly better shape than my 93 sprite. I would give it a go. But if you don't think you've got the skills, time or dedication to see it through to finish, then it might make more sense to sell it to someone that has. You could always put the money to an already restored one then.
I think now is the best time to get out if you don't think you can do it. Either way the mini gets saved and it's got to be better than rotting away as a half finished project. (Speaking from experience) 😃
Good luck for which ever path you choose
#15 se_juggles
se_juggles
  • 1,043 posts
Posted 27 June 2014 - 11:56 AM
thats in good condition compares to most i've seen on here lol (mine included)
Also tagged with one or more of these keywords: rust repair
