Me again! Becoming a habit!!
Lets start with the scraping. It sounds like its in behind the bulkhead and only occurs when the clutch is pressed down fully or its out of gear and the car has to be moving. The scrape is occurs once per rotation of the wheels.
Then there's the occasional knocking noise which doesn't appear to be the exhaust. There's something hitting the floor at the front, could this be the gearing linkage as there's about 2cm of movement up and down and left and right...
Cheers in advance
1 reply to this topic
Posted 27 June 2014 - 07:47 PM
Posted 27 June 2014 - 08:18 PM
Could be a number of things from your description,
Scraping
Possible stone or object stuck between the brake shield and disc,
Outer cv joint drive shaft,
Knocking
Worn gearbox mounts,
Worn engine mounts,
Worn engine steadies
Clutch release bearing
Scraping
Knocking
Worn engine mounts,
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
Mini Technical Sections →
Problems, Questions and Technical →
Rebuilt Engine Wont Crank With CompressionStarted by Kernreuben , 04 Jul 2025 ![]() |
1966 Mini S - Clutch IssuesStarted by MBradbury73 , 01 Jul 2025 ![]() |
Ac Dodd TuningStarted by Kevybmini , 04 Jun 2025 ![]() |
Am I Missing Something?Started by Rubbershorts , 21 May 2025 ![]() |
