Cutting Out And Not Starting Again
6 replies to this topic
#1 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 28 June 2014 - 09:14 AM
Basically yesterday was driving to my mates dipped my clutch to go around the corner and gear to 2nd and it cut out it was only running on 3 cylinders cause my ht leads are dead but after that it wouldnt start up again for a few minutes so started it up and limped it up to hers. So DexiWolf (dec) was round as well so we swapped number 4 ht lead with his an it ran fine untill the same corner where it cut out again!!! And wouldnt start for a few minutes again!!! So we turned the fuel up a little bit as it was really lean but on the way home i was running on all 4 cylinders came off a round aboutbit went down to 3 (this is with my ht lead back on) then it cut out again when i dipped my clutch
What could have gone wrong and how do i check and fix it.
P.s can i have an idiots guide please
#2 sledgehammer
sledgehammer
  • 3,101 posts
Posted 28 June 2014 - 09:43 AM
I would go with -
new leads esp coil lead (which sound old) & check plug condition
with it cutting out on corners , I would look in the float chamber & for water / dirt in fuel / tank
check the wiring around the coil / dizzi as movement may exaggerate a poor join / connection / bad wire
smarter folk will be along soon ;o)
Edited by sledgehammer, 28 June 2014 - 09:44 AM.
#3 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 28 June 2014 - 10:22 AM
I would go with -
coil lead and new HT leads is on the list
how do i check the float chamber
checking the wiring is going to be a fun job (the past owner bodges 90% of it and im slowly sorting it out)
so ill do them thanks :)
#4 sledgehammer
sledgehammer
  • 3,101 posts
Posted 28 June 2014 - 01:33 PM
has the float chamber got 3 screws on it ? -
if so undo them , have a look inside
you are looking for dirt & maybe a bit of water
if you have an integral float (HIF) then it's more complicated
#5 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 28 June 2014 - 01:58 PM
it only has 2 screws on the petrol thing :)
#6 sledgehammer
sledgehammer
  • 3,101 posts
Posted 28 June 2014 - 02:24 PM
can you get a pic ?
don't want you opening the wrong thing
#7 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 28 June 2014 - 05:05 PM
can you get a pic ?
ive been to PL Mini's and gotten 5 new HT leads and a new retard tube and it seems to be solved but it is running lean still so dec is going to look at it tomorrow for me :)
