Just Spent Far Too Much Money!
13 replies to this topic
#1 montyc
montyc
  • 308 posts
Posted 30 June 2014 - 05:45 PM
Just ordered 250 quids worth of kit from minispares and ebay!
Stage one kit (twin box rc40 for 998)
New alloy rocker cover with new screws
New pedal rubbers
Tin of yellow pain for my engine block
A load of new hoses
I only have a set of ramps to aid with the fitting of the stage one, should that be enough?
So bring on a few weeks of fitting the stage one and making my engine bay a bit tidier. Any suggestions on how to polish up any other bare metal (have a load of assorted sandpaper/wet and dry), or suggestions of what else i can do to sort out the mess that is my engine bay?
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 30 June 2014 - 06:01 PM
Did you not consider becoming a TMF+ member which costs a fiver and getting 7.5% discount at Minispares?
#3 Tezzer 52
Tezzer 52
    Just On Tickover
  • 8 posts
Posted 30 June 2014 - 06:03 PM
Attached File  mini engine.jpg   143.59K   30 downloads
#4 Tezzer 52
Tezzer 52
    Just On Tickover
  • 8 posts
Posted 30 June 2014 - 06:06 PM
just keep buying and fitting until you run out of money or space in the engine bay
#5 Berrybox
Berrybox
  • 261 posts
Posted 30 June 2014 - 06:08 PM
I fitted mine with a set of ramps and axle stands and it was easy enough. May be more awkward with only ramps but to be honest running it under the car was the simple bit after the fiddly engine bay stuff
#6 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 30 June 2014 - 06:09 PM
Could have saved about 20 quid!
#7 petey81
petey81
  • 1,341 posts
Posted 30 June 2014 - 06:16 PM
I remember once going into minispares just wanting some lower arm bushes and spent £300! Stupid items on the wall making me weak lol.
#8 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 30 June 2014 - 06:26 PM
I remember 2 months ago ringing minispares and spending over 2k haha... easily done
#9 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 30 June 2014 - 07:40 PM
How are you planning on getting the car setup after fitting the stage 1 kit? The best and easiest way to get the most out of it is with a rolling road session, so you might want to consider holding off on fitting the kit, if you haven't budgeted for one of those.
#10 montyc
montyc
  • 308 posts
Posted 30 June 2014 - 08:00 PM
Yep, rolling road is budgeted for, car is sorn now for about 5 months because im not allowed to drive it, so plenty of time to fit. Will have the car tuned down at slark engineering when ive done everything. So planning on taking alot of stuff off the car to clean it all up and make sure everything's alright
#11 Tomm
Tomm
  • 2,462 posts
Posted 30 June 2014 - 08:54 PM
I had this the other week.
Popped over after work and just reeled of a load of parts I was after, wasn't too bad at £308 but I went up there for £47 worth of stuff. £50 soon doubled and then doubled, and then a bit more!
#12 montyc
montyc
  • 308 posts
Posted 02 July 2014 - 09:36 PM
Had the bits arrived today! So i fitted the new manifolds... Horrendous job trying to get the exhaust manifold in behind the engine.
Just waiting for some grease to get here then the exhaust will be going on over the weekend along with everything else hopefully. Need to order a new inline fuse as i snapped one as i was getting things in behind the engine bay but other then that its a pretty easy job.
Any tips for getting the exhaust on right? As far as i can see i can find 3 places where the exhaust hangs off, one at the join to the manifold, one halfway down the car and one right at the back
#13 Dr s
Dr s
  • 428 posts
Posted 03 July 2014 - 03:01 PM
Exhaust is fairly straightforward but remember it hangs, it's not strapped on :-) easish with front and rear up in the air there will be wrestling to get it to line up.
#14 montyc
montyc
  • 308 posts
Posted 03 July 2014 - 05:12 PM
so keep it loose? im guessing the rubber washer type things the bolts go through let it move about a bit rather then being tight against the car?
