I'd like to fit the gps unit from a range rover into a mini can it be done as a straight swap
Rainge Rover Gps
gorseinonboy87
, Jul 01 2014 02:21 AM
2 replies to this topic
Posted 01 July 2014 - 02:21 AM
Posted 01 July 2014 - 06:47 AM
Anything is possible with time and money......
Posted 01 July 2014 - 07:03 AM
Apart from the obvious size issue which is easy to work out, the key is to find out if it is a self contained unit or whether it feeds from other electronics such as the ECU as lot of OEM stuff does these days. The easiest way to get an idea is to look how many wires feed it, if its self contained then I would expected a permanent live, switched live, earth and aerial, if there is a massive wodge of wires then chances are its going to be a pain. If it is self contained then it should be relatively simple.
