Thats put my mind at rest, thanks.
Is it off yet?
Posted 04 July 2014 - 12:17 PM
Is it off yet?
Posted 04 July 2014 - 12:20 PM
It really shouldn't take weeks of pressure on there to creep off.
Heating and cooling it will make a big difference, but the biggest thing is having a decent puller. The verto ones are far worse for sticking on that the diaphragm setup.
Posted 04 July 2014 - 01:43 PM
Well time is one thing I do have as doing shell, (got a thread on here for it). I have checked the TDC on pulley and the notch on pulley has been lined up with welded on bracket with line on it from the beginning so it must be just tight, that has to be TDC marks on bracket on timing cover to the right of notch in picture?
SAM_1555.JPG 62.5K
11 downloads
Posted 04 July 2014 - 01:51 PM
Posted 04 July 2014 - 01:55 PM
I will get some of that spray, thanks for your encouragement
Posted 04 July 2014 - 04:56 PM
That's neither the TDC marl or the pointer.
The mark should b a very fine notch - almost as though cut with a hacksaw.
The pointer is to the left of the pulley and is a series of triangular teeth, one (TDC) being larger than the others.
Posted 04 July 2014 - 05:12 PM
