Tapping Issues
Posted 03 July 2014 - 08:25 PM
Posted 03 July 2014 - 08:34 PM
fit a helicoil these are like a tight wound spring that you screw into the hole so you can use the smaller bolt to fit the helicoil .
dav
Posted 03 July 2014 - 08:35 PM
You need a Heli-Coil kit at 1/4" UNC size. With the kit you will get a special size drill, two taps and around 10 Heli-Coil wire thread inserts.
That is the professional way of doing the job.
Posted 03 July 2014 - 08:38 PM
Edited by patricksouth, 03 July 2014 - 08:40 PM.
Posted 03 July 2014 - 08:53 PM
Posted 03 July 2014 - 08:54 PM
Posted 03 July 2014 - 09:30 PM
I hope your second drilling though is not gone outside the scope of the correct sized heli coil
Posted 03 July 2014 - 09:48 PM
If it is vital that you have the car this weekend, you could try bonding a stud into the head using 'JB-Weld' or similar metal adhesive (Araldite 'Steel' for example).
Allow it to set and don't tighten the nut too far. it could be a temporary fix until the Heli-Coil kit arrives.
Posted 03 July 2014 - 11:17 PM
Or whack a metric bolt in there for the time being - that's how I found one of my heads.
Posted 04 July 2014 - 09:29 AM
Also you might want to look into what you are doing when you tap things if two attempts "haven't taken"
Posted 04 July 2014 - 01:25 PM
+1
I am sure neither of us wants to sound rude or insulting but before using a HeliCoil tap (or any other tap) review what you did before that made the tapped hole you produced not acceptable. Something must have been done wrong. It could be something trivial like your selection of the tap drill size.
For 75% thread (typical in industry) the rule of thumb is to subtract the pitch from the major diameter of the fastener and that is the tap drill size. For example, 1/4-UNC (the original heater stud size) is 1/4 x 20. 1/20" = 0.050". Therefore your tap drill for 1/4 UNC is 0.250" - 0.050" = 0.200"... so you can use a 5mm drill or a 13/64" fractional drill as the pilot drill for a 1/4 UNC tap
The HeliCoil kit may or may not come with the correct drill bit depending on the type of kit you buy AND if you buy a real HeliCoil brand kit. Regardless, somewhere on the instructions that come with the kit it will identify the size bit to use.
Posted 04 July 2014 - 01:37 PM
Posted 04 July 2014 - 11:24 PM
Yeah certainly did not want that to sound snide. I for one have wasted an awful lot of my own time but not having my mind fully on the job and choosing a drill size which is the full diameter of my intended fastener.
"Right, 6mm bolt, where's my 6mm drill bit. Drill drill drill. Tap tap. Hmmm. This feels a little too easy..."
Weld, grind, redrill, retap. Swear to pay more attention next time.
