I've been browsing the net looking at some filter options for a set of twin HS2 carbs I bought this week. They don't include an air box or any elbows, so the simplest options at this moment are:
Twin Cone/Pancake filters with stub stacks
http://www.minispare...ir/56-1630.aspx
http://www.minispare...ir/56-9335.aspx
Or
MED/ITG foam filter thingy
http://www.med-engin...ub-stack-system
I'm not a big fan of the foam ones, and I was wondering about getting an oval K&N and making a super sized pancake to cover both the carbs (similar to the backing plate on the MED system). Then I found this:
http://www.aptfast.c...r Kit Complete
They are also on ebay US for $121.99 plus $40 shipping to Australia...
Which looks exactly like what I wanted (except they say Midget or Sprite on them). It's not very expensive and it's got built in stub stacks. I know the carbs are on a different angle between Minis and MG Midgets, but is the carb spacing the same and does anyone think this would fit?
Here is a photo of the backing plate. The holes are in a very similar location to the MED kit. The filter size is 321mm wide by 83mm tall and 60mm thick:
Inside:
Cheers, Tim
Edited by timmy850, 04 July 2014 - 09:20 AM.
