Fuel In The Engine Oil
Posted 04 July 2014 - 09:00 AM
Posted 04 July 2014 - 09:26 AM
Unless both your fuel pump is dead and your engine sprung a leak, that sounds like two different issues.
How much fuel is there?
Posted 04 July 2014 - 09:29 AM
Posted 04 July 2014 - 10:21 AM
Posted 04 July 2014 - 10:42 AM
If you suspect fuel in the oil, DO NOT start the car as you have a nice incendiary device waiting to go off!!
Drain the oil and dipose of it properly. I can't stress enough how careful you need to be doing this.
Posted 04 July 2014 - 11:40 AM
Posted 04 July 2014 - 03:24 PM
Posted 04 July 2014 - 04:47 PM
fuel pump is normally the issue, if you have that much fuel from the rings, then your engine is ready for a reduild
dave
Posted 04 July 2014 - 06:53 PM
If there was a fuel leak somewhere down the back of the engine, then it is likely that it would collect some of the oil and muck that is undoubtedly lurking behind the engine - just a thought for all the people who think they have to be two separate problems.
Posted 04 July 2014 - 07:01 PM
