A Replacement For The Horrible Wing Mounted Aerial?
25 replies to this topic
#1 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 04 July 2014 - 04:41 PM
My car is nearing the end of it's time in the body shop, and I've seen in one of the pictures that the one of the wings used has an aerial hole. I really dislike the chrome telescopic aerials and it looks like the electric ones won't have enough clearance with the wheel.
So, would one of these work in its place? http://www.ebay.co.u...=item53f09b9889
I would imagine a signal amplifier would be needed as it's quite short, very low down. More to the point, would it look okay?
Any thoughts welcome :-)
#2 Miniminx71
Miniminx71
  • 508 posts
Posted 04 July 2014 - 04:56 PM
You can be quite creative with a wire coat hanger:
#3 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 04 July 2014 - 05:28 PM
that will work and you wont need an amp for it :)
#4 sledgehammer
sledgehammer
  • 3,109 posts
Posted 04 July 2014 - 05:55 PM
as above - shouldn't need an amp
set it back at the same angle as the window screen & should be ok
rubber duck as I recall
#5 pusb
pusb
  • 1,216 posts
Posted 04 July 2014 - 06:02 PM
I use one of these:
http://www.ebay.co.u...=p2054897.l4275
Does a decent job for me.
#6 HarrysMini
HarrysMini
  • 3,352 posts
Posted 04 July 2014 - 06:26 PM
I use one of these:
I was going to use an internal aerial, but then wheat do I do with the hole in the wing?
#7 pusb
pusb
  • 1,216 posts
Posted 04 July 2014 - 06:34 PM
I use one of these:http://www.ebay.co.u...=p2054897.l4275
Can't really help you there, mine wouldn't have had a radio originally so there is no hole in the wing.
#8 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 04 July 2014 - 06:40 PM
I use one of these:
weld it up :) paint over it
#9 HarrysMini
HarrysMini
  • 3,352 posts
Posted 04 July 2014 - 06:47 PM
I use one of these:
Bit late for that  :P
79F2AB71-5D5B-4213-9D18-426BF502FB31_zps
#10 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 04 July 2014 - 06:48 PM
I use one of these:
oh and love the colour :D
#11 GTIAlex06
GTIAlex06
  • 1,562 posts
Posted 04 July 2014 - 07:38 PM
Didn't you think of that before you had it painted!? :0
Aerial and side repeaters are going on mine
#12 mingy
mingy
  • 930 posts
Posted 04 July 2014 - 07:43 PM
I use one of these:
A pair of wing mirrors for extra visibility ??????
#13 HarrysMini
HarrysMini
  • 3,352 posts
Posted 04 July 2014 - 08:03 PM
I did actually. I supplied wings with no holes, but for whatever reason ones with holes were used.
It's not an issue really, as I need ones with side repeater holes anyway due to the age of the car.
#14 will_
will_
  • 201 posts
Posted 04 July 2014 - 08:53 PM
My dad's car has a 'bee sting' ariel fitted to the rear quater as it's a cabriolet. Could you not use similar ? It's black in colour. Would be a shame to just shove a bung in the hole on yours.
#15 will_
will_
  • 201 posts
Posted 04 July 2014 - 08:55 PM
This is it.
8CF2AB69-9153-4806-A9E6-47758F9C3782_zps
