Are Rivnuts Safe For Fixing Seats?
10 replies to this topic
#1 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 04 July 2014 - 10:05 PM
I need to come up with a way of installing MG ZR seats to a Mini, and something I've thought of would necessitate the use of Rivnuts.
For obvious reasons, the seats need to be very well secured, so will rivnuts be secure enough? I've read about other's using them, but I'm not sure..
Any thoughts welcomed.
#2 Cooperman
  • 23,320 posts
Posted 04 July 2014 - 10:15 PM
Rivnuts are not designed for high load applications. They are for light loading only.
For seat fixing it is better to MIG-weld the nuts to the structure.
#3 petehuws
petehuws
  • 329 posts
Posted 04 July 2014 - 10:26 PM
The only time I ever used rivnuts was to repair stripped water bottle cage threads on my pushbike.  Cooperman is on the ball; Mig weld nuts...
#4 HarrysMini
HarrysMini
  • 3,352 posts
Posted 04 July 2014 - 10:28 PM
MIG welding the nuts definitely sounds like the safest option; that's probably what I'll end up doing.
#5 Cooperman
  • 23,320 posts
Posted 04 July 2014 - 10:33 PM
RivNuts are fine for things like wheel arch extensions, spot lamp steady bars, trim items, additional instrument panels, extra fuse boxes, switch brackets and other low load non-safety critical items.
#6 HarrysMini
HarrysMini
  • 3,352 posts
Posted 04 July 2014 - 11:53 PM
That's what I bought them for, I want to replace all the rust-prone self tapping screws with them.
#7 Cooperman
  • 23,320 posts
Posted 05 July 2014 - 06:16 PM
I often use RivNuts to replace self tapping screws. I also tend to use stainless steel cap head screws rather than slot or Phillips head screws. The additional instrument panels in my rally 'S' are covered with black leathercloth and held in with M4 RivNuts and Stainless cap head screws.
#8 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 05 July 2014 - 06:29 PM
i look at it like this
if you could possibly pull the item off with your bare hands when attached normally, rivnuts will be a good replacement for the fixings.  if you DO NOT want to be able to pull it off with your hands, DO NOT use rivnuts.
#9 Cooperman
  • 23,320 posts
Posted 05 July 2014 - 06:42 PM
Then there are the 'worse than useless' engine mountings with RivNuts!
#10 Artful Dodger
Artful Dodger
  • 4,435 posts
Posted 05 July 2014 - 06:57 PM
thats so daft!    crap aluminium thread holding your engine in, no thanks!!
#11 sledgehammer
sledgehammer
  • 3,107 posts
Posted 05 July 2014 - 07:35 PM
We use H/D steel bolhoff's at work (similar in principle to rivenut's)
they can hold a lot of weight , used to lift machinery (around 1/4 ton on 2 m8 threads) on 60x8 mm bar hangers
they even go thru hot dip galv , on test the m8 10.9 bolt fails before the bolhoff ever does
we make thousands per year without failure
but the steel thickness needs to be 3mm + for the smaller ones - so no use on a mini the mini would tear before the bolhoff
I used to use similar fixings when I used to make lorry bodies , Monel rivets & other rivet types
these are all steel rivet/nuts and need to be set with a special gun
not all rivets are equal
but ally rivenuts are going to be as weak as an ally nut/bolt
Edited by sledgehammer, 05 July 2014 - 09:20 PM.
