Rear Shock Absorber Fitting
4 replies to this topic
#1 psoutzis
psoutzis
  • 278 posts
Posted 05 July 2014 - 09:11 AM
Hi, i have removed my rear shocks to replace the subframe bushes but forgot how to install them correctly... it has 2 bushes and a pulley each.
I install it with the 2 bushes and the pulley from underneath the arch, (see picture) and doesnt feel good, i hear bad noises ! What is the correct way ?
My shock absorbers are Bilstein
Regards, Panayiotis
#2 surfblue
surfblue
  • 1,827 posts
Posted 05 July 2014 - 09:30 AM
By 'pulley' I assume you mean washer?
1 rubber bush on shock below shell, 1 on top inside boot and washer / pulley on top.
The 2 bushes isolate the shock from the shell, preventing the strange noises that you are hearing.
#3 psoutzis
psoutzis
  • 278 posts
Posted 05 July 2014 - 09:40 AM
Thank you, my mistake , its a washer..
And there are 2 washers..
So i will fit the bush over the shock then the washer, and in the boot , fit the bush first then the washer and the nut.... right ?
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 05 July 2014 - 09:52 AM
Washer rubber wheel arch side then rubber washer nut inside boot.
#5 psoutzis
psoutzis
  • 278 posts
Posted 05 July 2014 - 11:45 PM
Thank you !!
