clutch / drop gear chatter
8 replies to this topic
#1 supermotolee
supermotolee
  • 1,120 posts
Posted 22 June 2006 - 09:10 PM
hello all
well today i got my new engine running properly for about the first time. i'm very nervous as its my first engine build. i was about ready to test out the clutch so i bled it, i could then hear a chattering coming from the clutch side and it goes away when you push the clutch pedal down. i have fitted straight cut gears and an ap clutch plate and orange diaphragm. the clutch is also very juddery when you start to let it out i put this down to being new
once again any ideas ? thanks lee
#2 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 23 June 2006 - 06:54 AM
SC drops chatter... full stop..
#3 english-bully
english-bully
  • 281 posts
  • Local Club: " CREWE'S MISSILES "
Posted 23 June 2006 - 08:57 AM
Guessworks correction dont panic,straight cut drop gears chatter...just lift the tick over up a little sometimes shuts em up a tad LOL !!!
#4 lilly
lilly
  • 41 posts
Posted 23 June 2006 - 05:45 PM
phew i was wondering if i had built something wrong as i forgot to put the bloody washer on the crank under the timing cover already causing the pulley to rub so confidence is not high lol
well the chattering goes when you put the clutch down any ideas why?
thanks guys
#5 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 23 June 2006 - 06:04 PM
When you put your foot on the clutch you are disengaging the drive to the drop gears so they aint gonna chatter then! :D
#6 Purple Tom
Purple Tom
  • 4,921 posts
Posted 23 June 2006 - 07:52 PM
if you have a slightly lumpy cam it will also exacerbate the noise, as the tickover isn't smooth and therefore the gears will chatter even more.
Get it set-up correctly ASAP and you should find the chatter more or less settles down. Mine chattered quite loudly (SC box and drops), but after a tuning sessiong with AC Dodd at ML Motorsport the noise all but disappeared.
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 23 June 2006 - 07:59 PM
Are you talking about the oil flinger? I hope you did put it in after you found it wasn't there.
The orange spring is savage, it's probably juddering because your ankle hasn't adapted to it yet. Just be glad it's not a double grey, you end up with Popeye's legs using that thing.
#8 supermotolee
supermotolee
  • 1,120 posts
Posted 23 June 2006 - 10:26 PM
yeah dan the oil flinger dont worry its in now, and yes its a bit of a grabby clutch but i wanted something that would grip hard hoping this engines gonna be pretty fast 100bhp maybe
got a 286 cam so yes its pretty lumpy and 1.5:1 roller rockers so idle is a bit of a problem haha
all good fun
thanks for all the help
#9 supermotolee
supermotolee
  • 1,120 posts
Posted 24 June 2006 - 11:01 PM
another question i'm going to finally try and sort the mixture as best i can and timing tomorrow and take it for some propper drives but how long should i run it in for?500 miles? i was thinking of doing a few oil changes over a 500 mile period and then taking it to be set up roperly on the rr already i can feel its pretty quick and thats only taking it round the block
lets hope the clutch gets less grabby its like a paddle clutch at the moment haha
thanks lee
