Bought this off Brett but the impending arrival of twins has resulted in some changed priorities! Shame really as I was sooo looking forward to using it!
Keep your eye's open for more bits coming up for sale as I'm planning on getting rid of the Clubby and all the shiny bits I had bought for it. On to the advert!!!
In this pretty much bolt on setup is:-
Metro Turbo exhaust manifold modified to suit the GT20, the ports have been opened out to the manifold gasket, the dividers have been cut back and the manifold very well ported, it comes fully assembled with the turbo on it using a Paul S T3-T2 adapter plate which Brett blended to match both the turbo and manifold. The downpipe was made by Brett and was the 3rd version (the turbo to downpipe flange is also a Paul S item), it can be fitted/removed with the engine in place and puts the exhaust in about the same place as a normal system, it starts at 63mm and works its way down to 51mm and will mate via a slip joint to a standard 2 inch system complete with wideband boss.
Genuine Garrett GT2056 bought from cossierick in the group buy (less than 2000 miles). Actuator has been relocated and the housing clocked to suit mini installation, the wastegate port has also been opened up as Brett had issues with boost creep at high rpm (porting the wastegate resolved this)
Also included is the braided oil feed (these are genuine aeroquip fittings and cost in excess of £80!) and turbo to block oil return (I have misplaced the silicone hose but I should be able to find a replacement).
I haven't taken any current pictures yet as it's wrapped up in a box under my workbench but have put some pictures up from Brett's old for sale thread and build thread. Everything looks the same (except a bit dirtier! lol)
I paid £525 for this setup so would like that or nearest offer.
Can deliver to MITP or the IMM.
Current Downpipe
Turbo on Manifold (old version of DP)
Oil Feed bits (from brett's build thread)
Oil return (from brett's build thread)
Edited by John H, 08 July 2014 - 02:53 PM.
