Vacuum Gauge
9 replies to this topic
#1 pusb
pusb
  • 1,216 posts
Posted 07 July 2014 - 09:40 PM
I think this has been asked before on here but I just want to check before pulling pipes out.
On the attached picture, is the circled pipe where I can connect a Vacuum gauge to?
If so does that existing pipe just pull straight off with brute force?
Thanks,
Attached File  vac.jpg   40.61K   44 downloads
#2 gazza82
gazza82
  • 3,020 posts
  • Local Club: TMF+
Posted 07 July 2014 - 10:19 PM
That's for distributor vacuum advance and might be too small in diameter. But it will pull off then you need a t-piece to connect gauge in.
On my old A35 I had a plate between SU carb and inlet and fitting in that. But that was in 70s!
Edited by gazza82, 07 July 2014 - 10:19 PM.
#3 jelboy89
jelboy89
    Formally known as jr4sr4eva
  • 169 posts
Posted 07 July 2014 - 10:27 PM
Like this gazza
http://minispares.co...83.aspx|Back to
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 08 July 2014 - 12:21 AM
As stated above, don't use the vacuum advance take off from the carb, use the carb spacer with the barbed nipple.
A vacuum gauge is meant to monitor manifold vacuum, not ported vacuum.  The carb spacer will connect to manifold vacuum.  The connection on the carb connection can be for ported vacuum which means it is monitoring the vacuum in the carb venturi, not what you want.
#5 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 08 July 2014 - 03:12 AM
I've installed one of those spacers this morning. Previously it was on the distributor advance and it didn't read right at all.
Edited by timmy850, 08 July 2014 - 03:38 AM.
#6 pusb
pusb
  • 1,216 posts
Posted 08 July 2014 - 05:13 AM
How difficult was it to fit?
#7 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 08 July 2014 - 06:01 AM
Easy!
Unbolt carb and remove gaskets and old spacer
Clean up gasket surfaces
Install new gaskets and spacer plate
Connect rubber vacuum hose.
My new vacuum spacer wasn't completely flat, so I used some wet and dry and a flat surface to sand it smooth.
#8 pusb
pusb
  • 1,216 posts
Posted 14 July 2014 - 06:39 PM
Easy!Unbolt carb and remove gaskets and old spacerClean up gasket surfacesInstall new gaskets and spacer plateConnect rubber vacuum hose.My new vacuum spacer wasn't completely flat, so I used some wet and dry and a flat surface to sand it smooth.
Thanks for the info, I'm just looking at ordering one of those on minispares, but there is more than one type depending on what type of carburetor is fitted.
What sort would mine be? Its a 1979 850 engine.
#9 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 14 July 2014 - 09:52 PM
The HS2 or 1 1/4" carb has the bolt holes vertically and a skinnier top on the dashpot.
http://www.minispare...ure=600/HS2.jpg
The HS4 or 1 1/2" carb has them on an angle
http://www.minispare...350/FZX3013.jpg
It could also be something else entirely as minis get changed around all the time!
#10 pusb
pusb
  • 1,216 posts
Posted 15 July 2014 - 05:24 AM
Thanks Timmy, mine looks like a hs4.
