Right, hepolite make 1275 turbo pistons, but they also have a range of pistons (one im interested in are the +020) with 8.8 compression. These sets are ridiculously cheap (62 pounds from avonbar)...
Question is, will they last in a 1293 turbo motor? The compression seems good for turbo applications...
Hepolite Pistons for turbo
Pavel
, Jul 01 2004 11:31 AM
1 reply to this topic
Posted 01 July 2004 - 11:31 AM
Posted 01 July 2004 - 05:35 PM
As they are for normally aspirated use they will have thinner crowns than a Turbo specific piston, so generally will not be able to handle the heat & loads a good Turbo piston would. You may be safe to run a low boost level with these, but as i've never tried them in a Turbo setup i couldn't advise you how robust they are. I guess it's one of those try it and see situations ? Or preferably pay the extra and get some proper Turbo jobbies ....... :grin:
Phil.
Phil.
