can the poly bushes on the front subframe make that feeling that the subframe / engine moving
like a clunk clunk foot on foot off the type when the top engine steady worn. Or when those rubber mounts at the top worn
its definitely not the engine moving
if you put a crowbar in where top mounts are with the wheel off you can see some movement there
I thought it might diff movement or driveshafts hows best way to check as its realy annoying
