Water Pump Pulley
8 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 10 July 2014 - 06:04 AM
Is there any difference in what size water pump pulley I run
It's a 1380
#2 Gremlin
Gremlin
  • 2,142 posts
Posted 10 July 2014 - 06:06 AM
The bigger the pulley the slower the pump will run, so if you plan on doing lots of high rpm driving/racing/rallying go for a bigger one
#3 jime17
jime17
  • 948 posts
  • Local Club: None
Posted 10 July 2014 - 08:06 AM
I'm sure I read that some 1275 heads can foul a larger pulley.
#4 minilee94
minilee94
  • 3,523 posts
Posted 10 July 2014 - 09:01 AM
I thought the big one fails too I have a small one ATM but iv not run the engine yet
#5 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 10 July 2014 - 10:12 AM
As above, a smaller pulley spins the water pump faster and a larger pulley spins it slower. You want a larger one if you are going to be doing lots of high-RPM driving as if the water pump spins too fast, it becomes very inefficient.
Looking at your build, I imagine it is going to be seeing high RPM fairly regularly (and possibly be tracked?), so if I were you I'd fit a larger one.
I'm not sure about fouling, I guess all you can do is buy a cheap second hand one and fit it and spin it and see.
Edited by HarrysMini, 10 July 2014 - 10:13 AM.
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 July 2014 - 11:22 AM
The large pulley in 4.75" in dai and can foul on the head if the head has been skimmed at some stage, only way is to try one and see
#7 minilee94
minilee94
  • 3,523 posts
Posted 10 July 2014 - 04:10 PM
I spoke to mini spares and I'm going to run the one I have which is medium sized pulley
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 10 July 2014 - 08:43 PM
The largest ones foul A series heads but clear A+ heads. There are more than 2 sizes too.
#9 minilee94
minilee94
  • 3,523 posts
Posted 10 July 2014 - 09:06 PM
Mine a a+ block but a 12g938 head (12g940) head
Iv got my old style pulley from my 1000 auto and that fits and I'm getting a large pulley tomorrow
