Can't Hit The Rev Limiter
21 replies to this topic
#1 Island Mini
Island Mini
  • 448 posts
  • Local Club: Wish there was one
Posted 10 July 2014 - 07:09 PM
I've just finished setting up twin hs2's and The engine is lively and revs perfectly all the way up to the red line but after reinstalling my pancake filters I can barely get to 5k. Do I have an air restriction? Or are the air filters just altering the mixture.
#2 Domneon
Domneon
  • 720 posts
Posted 10 July 2014 - 07:13 PM
The air filters will affect the mixture
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 July 2014 - 07:27 PM
This pancakes do restrict air flow and hence a richer mixture, have you rechecked the mixture with the filters on?
#4 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 10 July 2014 - 07:31 PM
An air filter will create a restriction so that for a given amount of fuel, less air will be able to mix with it. Hence you ending up with a richer mixture.
I would personally be getting it on a rolling road and get them set up with correct needles etc.
#5 Island Mini
Island Mini
  • 448 posts
Posted 10 July 2014 - 07:35 PM
Okay thanks for the assistance.
I'll go lean it off and report back,
#6 carbon
carbon
  • 2,590 posts
Posted 10 July 2014 - 08:05 PM
What make of pancake filters are you using?
If they are the shiny chrome ones with wire wool insides then you'll be doing well to make any decent power at 5000rpm. Plus they are pretty useless at keeping out anything smaller than a 1/4 nut...
A pair of decent K&Ns with stub stacks will flow and filter effectively.
#7 HarrysMini
HarrysMini
  • 3,352 posts
Posted 10 July 2014 - 08:07 PM
And cost you as well, decent K&Ns and stub stacks will set you back £240 for the pair.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 10 July 2014 - 08:22 PM
But we know costs does not come into owing a mini ;D
#9 sledgehammer
sledgehammer
  • 3,129 posts
Posted 10 July 2014 - 08:52 PM
 Owing a mini - more honest than saying Owning a mini
I'm always Owing for parts on mine
#10 carbon
carbon
  • 2,590 posts
Posted 10 July 2014 - 09:23 PM
You often get K&Ns coming up second hand. .
With a good wash and re-oiling they can work as good as new...
#11 Island Mini
Island Mini
  • 448 posts
Posted 11 July 2014 - 01:07 AM
They are indeed the el cheapo foam rubber shiny ones. I'm selling the car next month so I just need it to look pretty for now when you open the bonnet. I leaned it off, gapped and cleaned the plugs throttle response much better and can just about make it up to 5300 rpm which for an auto is plenty! Probably if I had a rolling road and access to every needle out there in my back garden I would get it sorted. But for now I'm happy!
Anyone got any other words of wisdom whilst I'm here? New to this whole carb thing as I was an injection guy originally. (My SPI system never got above 4500rpm due to dodgy wiring and sensors from the previous owner!)
#12 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 July 2014 - 05:25 PM
Des Hammill has a book which is very good on Carbs http://www.amazon.co...s/dp/1845840739
#13 Island Mini
Island Mini
  • 448 posts
Posted 11 July 2014 - 11:59 PM
Noted. Thanks!
Also fixed my all issues today with idling etc, pulled the carbs as I wanted to fix the lifting pins which were seized when I bought the carbs. Turns out I had multiple air leaks, one of my jets weren't centred and my piston oil level was low. All stuff I thought I checked but I guess there's nothing like a good tune up!
#14 Island Mini
Island Mini
  • 448 posts
Posted 12 July 2014 - 12:10 AM
Now got the issue of finding some way to attach the kickdown to the throttle. Making my auto painfully slow.
#15 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 12 July 2014 - 10:51 AM
Custom made bracket of sorts ?
