Fitting Original Seats
11 replies to this topic
#1 evilpen14
evilpen14
  • 115 posts
  • Local Club: CCC and RAF Mini Club
Posted 12 July 2014 - 10:13 AM
My mini has buckets seats in and I'm changing it back to the original. I don't have runners in the car anymore, the buckets seats are attached a different way. Is everything on the subframes of the seats I need.
#2 RooBoonix
RooBoonix
  • 1,225 posts
Posted 12 July 2014 - 11:24 AM
The original seats, provided they have their frames attached just bolt to the front mounts on the cross member and pivot forward on that. On newer cars they lock into place on the locking ring on the floor by the handbrake lever.
I hope that is what you were asking about?
Cam.
#3 69k1100
69k1100
  • 376 posts
Posted 12 July 2014 - 12:22 PM
No, there's two brackets that bolt to the four holes (captive nuts) in the front of the crossmember.
#4 evilpen14
evilpen14
  • 115 posts
Posted 12 July 2014 - 05:02 PM
Thank you very much :)
#5 RooBoonix
RooBoonix
  • 1,225 posts
Posted 12 July 2014 - 05:55 PM
No problem :) I will say, the holes where the captive nuts are in the cross member, on my car at least, have "stretched" so the mounts flex a little. To fix it I added some big washers to spread out the load onto some "fresh" metal which seemed to make them sturdier.
Just a tip if you find your mounting holes to be the same.
Cam.
#6 Dusky
Dusky
  • 5,322 posts
Posted 12 July 2014 - 08:23 PM
What bolts.do you nees for them?( searching them because.previous owner didnt.have them..)
#7 evilpen14
evilpen14
  • 115 posts
Posted 13 July 2014 - 09:27 PM
Cool I will probe be in touch soon. Not collecting them till thursday and gonna try fitting them friday afternoon. :).
Thanks for the tip.
#8 RooBoonix
RooBoonix
  • 1,225 posts
Posted 13 July 2014 - 09:38 PM
No idea on the bolts, mine came with them already fitted. They are super easy to fit. Good job really as you'll often find yourself with the seats moved out/back off the mounts in order to work inside the car :D
Cam.
#9 robsrallymini
robsrallymini
  • 150 posts
  • Local Club: Cannock and District car club
Posted 16 July 2014 - 08:27 PM
Hi there .I'm just refitting standard seats , does anyone have a picture of the seat locking ring on the floor. I have tried minispares but apparently
they don't do them anymore.
#10 Dusky
Dusky
  • 5,322 posts
Posted 16 July 2014 - 08:52 PM
this?
 https://www.minispar...|Back to search
#11 robsrallymini
robsrallymini
  • 150 posts
Posted 17 July 2014 - 06:32 PM
That's strange as I was only speaking to a member of staff at minispares the other week about this.
Thanks for that .
#12 evilpen14
evilpen14
  • 115 posts
Posted 22 July 2014 - 06:54 AM
I have fitted the seats back in now. Starting to look much better :).
