Engine Stuttering In The Rain
5 replies to this topic
#1 samt88
samt88
  • 445 posts
Posted 12 July 2014 - 08:45 PM
Hi guys,
When my car is in heavy rain it starts to sputter and struggle, not it's usual self after a nice rolling road tune!
The rain cover is in place. Is there anything else I can do to ensure it's reliable in the rain?
Cheers,
Sam
#2 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
Posted 12 July 2014 - 09:14 PM
Electronic ignition?
#3 Cooperman
  • 23,315 posts
Posted 12 July 2014 - 09:18 PM
Take the cover off then remove the distributor cap. Dry it out thoroughly with a heat gun or hair dryer.
Re-fit, then seal the cap with a non-conductive silicone grease plastered all over the cap where the leads go into it and around the join line between cap & distributor body. Finally spray with ignition sealer then re-fit the water shield.
#4 samt88
samt88
  • 445 posts
Posted 12 July 2014 - 10:49 PM
Cheers cooperman - I'll try that out! I've only got the car for a few more months so I'll save off the electronic ignition for this one.
#5 Cooperman
  • 23,315 posts
Posted 12 July 2014 - 11:09 PM
I've always run points ignition because that is required for historic rallies and I don't run with a water shield as it restricts quick access to the front of he engine.
I waterproof as I've suggested and I can go through deep fords with no problems and no hesitation. You can use an aircraft control cable grease or even Vaseline, then liberally spray with Ignition Sealer.
#6 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 13 July 2014 - 05:32 AM
When I used a dizzy, I was a marigold man, always worked great
