Ignition Advance Curves
8 replies to this topic
#1 propernasty
propernasty
  • 77 posts
Posted 13 July 2014 - 08:42 AM
Hi ive just fitted a stealth black box ignition system to my car. its a box which goes between the dizzy and the coil and It lets you customise the advance curve using a pc. Its really simple and should avoid my pinking problems i had with the original distributor.
does anyone have any ignition advance curve details as i want to start playing around but it would be nice to start in the right ball park. Im running 10.5 to 1 compression and a 296 cam.
Any help much appreciated
Graham
#2 propernasty
propernasty
  • 77 posts
Posted 13 July 2014 - 08:44 AM
#3 Dusky
Dusky
  • 5,322 posts
Posted 13 July 2014 - 10:05 AM
Search for the aldon yellow/red curve.
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 13 July 2014 - 10:25 AM
Its in the faq section herehttp://www.theminifo...advance-curves/
and you want the Aldon Yellow one
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,767 posts
Posted 13 July 2014 - 12:42 PM
If it were mine I'd set a static setting on 6 degrees. Then have;
Point 1 @ 1 = 0
Point 2 @  900 = 8
Point 3 @ 1500 = 12
Point 4 @ 2000 = 16
Point 5 @ 3000 = 20
Point 6 @ 4000 = 22
Point 7 @ 6000 = 22
AC
Edited by ACDodd, 13 July 2014 - 12:50 PM.
#6 Dusky
Dusky
  • 5,322 posts
Posted 13 July 2014 - 02:03 PM
Let me know how the stealth works, Considering buying a unit myself too. How hard is the fitment?
#7 timmy850
timmy850
  • 3,388 posts
  • Local Club: MITG
Posted 14 July 2014 - 05:48 AM
Here is a thread from an Aussie forum discussing it...
http://www.ausmini.c...php?f=2&t=83483
#8 propernasty
propernasty
  • 77 posts
Posted 16 July 2014 - 09:28 PM
the stealth is easy to fit, it takes 10 mins + the time needed to wire off the advance weights in the dizzy, the  software is clunky, you can only upload with the ignition off, the rev limiter is brilliant im pretty chuffed with it, it will be much better when on the dyno. Thanks for all the hints i will bang in the settings above nad see what happens
Graham
#9 propernasty
propernasty
  • 77 posts
Posted 17 July 2014 - 07:08 AM
the fella in Australia has obviously spent alot of time on this, its a really good article
