Line Bore Or Re-Bore?
9 replies to this topic
#1 tomgale
tomgale
  • 558 posts
Posted 13 July 2014 - 02:24 PM
I'm planning a new engine, changing my 998 to a 1098 and I purchased a +20 A+ block and 1098 pistons. but when I got it it turns out the bearing caps have gone AWOL at some point in its life, I know these are matched to the block, and it isn't much good without them.
so my options are (if they're even possible)
1- acquire new bearing caps and line bore the block to suit them
    pros- can use block with correct 1098 number, didn't waste money on it, can sell my 998 after
    cons- who would even sell caps separately?, can line boring the block to suit new caps even be done?
2- take my current 998 block out, re-bore it to +20 to suit pistons, build engine on that block
     pros-re-boring is probably a more common operation? easier to get done?, can keep car's original engine number (though at the wrong displacement)
     cons- have to have the engine out of the car for much longer, annoying as its my only vehicle.
so, what Im asking is, if option 1 is possible, how does it compare cost wise to option 2?
thanks!
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 13 July 2014 - 02:32 PM
Line boring is quite expensive I believe.
Reboring is likely to be cheaper
#3 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 13 July 2014 - 04:54 PM
option 3. find another 1098 engine and rebore it. would be the cheapest way, plus you keep the 998 in your car and your car on the road.
#4 ACDodd
ACDodd
  • Mini Docs
  • 2,746 posts
Posted 13 July 2014 - 05:04 PM
The 998 and 1098 blocks are the same. Simply fit the 1098 crank and pistons into the 998 block. Rebore the 998 to fit the +0.020" pistons.
AC
#5 tomgale
tomgale
  • 558 posts
Posted 13 July 2014 - 06:40 PM
anyone know roughly the price difference between a rebore and a line bore? if its only 50 quid or so I'll probably go with the line boring, I know the blocks are the same but being without a car for a few weeks would be a huge pain in the arse. as for option 3, my brothers clubman estate's engine is on the desk at the moment, I could borrow his block then give him mine, but his isnt A+ whereas all the transfer and primary gears ill be using are, is this a problem?
#6 Cooperman
  • 23,293 posts
Posted 13 July 2014 - 10:16 PM
Rob Walker Engineering of Witney, Oxon., can line-bore main bearing caps.
You could call him for a price.
#7 dean
dean
  • 283 posts
  • Local Club: EDMC
Posted 13 July 2014 - 10:18 PM
line boring.
http://www.robwalker...inereaming.html
cylinder boring
http://www.robwalker...der_boring.html
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 14 July 2014 - 06:52 AM
I'll keep that 1275 block with the caps missing at that price
#9 The Principal
The Principal
  • 763 posts
Posted 14 July 2014 - 04:49 PM
If you need new bearing caps you will need to have the thrust faces machined too, last time I had steel caps with line boring and thrust faces machined by Gosnays cost me best part of 500 excluding the steel caps. New caps are available via MED or Swiftune incase your lottery numbers come up.
#10 tomgale
tomgale
  • 558 posts
Posted 14 July 2014 - 07:32 PM
yeah, thats... a lot. dont suppose anyone has a +20 998/1098 block lying around? ;)
