Ignition Issue?
Posted 14 July 2014 - 02:05 PM
Daniel
Posted 14 July 2014 - 02:40 PM
Usually when the rev counter goes erratic with the engine missing it points to a low tension issue on the ignition circuit, disconnect the rev counter off the coil - terminal and retest the vehicle to see if its inside the rev counter. If its still doing it then check your points/condensor if your not electronic and all the Low Tension Wiring to and from Coil/Distributor.
Posted 14 July 2014 - 03:01 PM
Posted 14 July 2014 - 03:02 PM
Could be disconnect it and road test it and then move onto the other items if required.
Posted 14 July 2014 - 04:25 PM
Ok i will try that later, now I think about it, in the past the Rev counter has stopped working and then started again after about a minute and also when I turn off sometimes the Rev counter jumps to about 3000 before going to 0 but neither of these involved the engine misfiring, would this be a related issue?
As Dave said, the issues may be (and probably are) related to a problem inside the tach. As was pointed out, a voltage sensing tach is connected to the coil (-) terminal. If there is an internal problem with the tachometer and that problem creates an intermitent short to earth of the sense (white/black) wire, the ignition may be disabled. Basically the tach may be acting like a kill switch if it is shorting the sense wire to earth.
