Hi,
I want to upgrade my 1998 MPi with a stage3 kit (+-80ps).
I was wondering if I need to upgrade the cooling system as well? any suggestions as I can only find the standard front mount radiator on minispares...
Regards Sam
Posted 16 July 2014 - 09:58 PM
Hi,
Regards Sam
Posted 17 July 2014 - 07:04 AM
shouldnt need to, all the components in the mpis including the ECU are rated for up to about 90 bhp, however fueling may need to be altered with a chip. like everything else being too cool it can actually be detrimental.
VMAXSCART do a cooling system for the mpi if you do want to go down that route.
Posted 17 July 2014 - 08:25 PM
ok, thanks!
Posted 18 July 2014 - 06:25 AM
Posted 18 July 2014 - 06:26 AM
Posted 20 July 2014 - 02:51 PM
however you gan get a fuel pressure regulator from stuart at vmax which is fitted ti the cooper S to adjust the fueling to allow for the bhp increase :)
Posted 20 July 2014 - 10:16 PM
shouldnt need to, all the components in the mpis including the ECU are rated for up to about 90 bhp, however fueling may need to be altered with a chip. like everything else being too cool it can actually be detrimental..
Posted 21 July 2014 - 04:27 PM
Chip? You can't alter the MEMS, the fuelling is mechanically controlled with a pressure regulator.
FS
http://www.minispeed...hips-icon-unit/
superchip icon
although only allows you to adjust ignition timing(i said fuel i was wrong, i meant timing but fuel pressure regulator was on the brain) and is not really worth it for the bhp gains but still.....its a chip
Edited by Fossy313, 21 July 2014 - 04:29 PM.
Posted 22 July 2014 - 06:09 AM
Edited by tomm, 22 July 2014 - 06:11 AM.
