Welding Gas Flow Rate
27 replies to this topic
#1 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 17 July 2014 - 09:54 AM
Morning,
What gas flow rate do you lot weld at on your minis?
On my welding course my tutor was telling us to weld at 15L/min but I think it should be lower, around 10-12L/min for the mini?
Any comments appreciated.
John
#2 henri1972
henri1972
  • 277 posts
Posted 17 July 2014 - 09:56 AM
normally 12 L/min is what i have always used
#3 Hendred
Hendred
  • 484 posts
Posted 17 July 2014 - 09:58 AM
Ok thanks
#4 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 17 July 2014 - 10:00 AM
I don't go by a flow rate, I put the torch to my ear and listen to the hiss of gas (make sure it's not feeding wire!), my logic is that you need just enough gas to form around the weld.
So a gentle 'hiss' seems to work best for me ....also consider if you are working in windy conditions, even a gentle breeze can blow away the shielding gas.
Are you using Co2 or an 5% Argon Co2 mix?
#5 Hendred
Hendred
  • 484 posts
Posted 17 July 2014 - 10:20 AM
93 Argon, 5 Carbon Dioxide, 2 Oxygen mix
#6 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Half that. But you'll not go wrong with too much, only too little. Get some scrap steel and practice, see what your welder works best at.. Welding position also has a bearing on gas flow.
#7 Hendred
Hendred
  • 484 posts
Posted 31 July 2014 - 03:31 PM
Been welding today at level 2 on my 140amp welder and 8L/min of gas seems to give the best weld.
Front and back of test welding, certainly penetrating.
Attached File  SAM_1701.JPG   44.83K   15 downloads
Attached File  SAM_1702.JPG   49.98K   12 downloads
#8 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 31 July 2014 - 06:15 PM
I think my mig welder is set at around 12 Litres/min
#9 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,144 posts
  • Name: Sean
Posted 31 July 2014 - 06:19 PM
I use about 10 litre per minute
#10 sledgehammer
sledgehammer
  • 3,102 posts
Posted 31 July 2014 - 06:39 PM
Use the minimum L per min to avoid oxidization - unless you have a free supply of gas - otherwise £xpensive
I use 8 lpm on small welds - but remember the gauges aren't that accurate anyway - one slight tap & they are out of calibration
& keep the defusser , nozzle , & tip nice & clear / clean - you don't want to squirt a jet of gas , just gently cover the weld with it
much too high will be as bad as too low - when very high the gas draws air in from behind the nozzle & oxidizes the weld
watch out with cooling fans in the hot weather - it don't take much to blow the gas out of the weld area
best of luck
#11 Hendred
Hendred
  • 484 posts
Posted 31 July 2014 - 07:01 PM
Thanks for the advice, I stay between 8-10l/min
#12 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 31 July 2014 - 07:56 PM
And that is why those tiny 110 litre bottles are so expensive to use.
#13 Hendred
Hendred
  • 484 posts
Posted 31 July 2014 - 08:05 PM
Tiny 110 litre?
#14 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 31 July 2014 - 08:07 PM
Tiny 110 litre?
yeah, the crappy little disposables that small and mid range welders come with. They cost about a tenner each as well! Only good for ten- fifteen minutes continuous welding.
#15 Hendred
Hendred
  • 484 posts
Posted 31 July 2014 - 08:10 PM
Those are crap but they arent 110 litre, I have a big bottle that is only 9 litres unless we are getting our wires crossed
