Headlining Alternative With Stereo.
10 replies to this topic
#1 jon_barnes77
jon_barnes77
  • 35 posts
Posted 18 July 2014 - 10:59 AM
I'd pulled my headlining out years ago and never got round to sorting it, until now. I decided it was time to fit a stereo (i'd been running my iphone + amp set up for years). So i bought a mechless radio/sd/USB as it's a lot shorter than a normal stereo. and plonked it up here.
Attached File  01-mdf.jpg   71.54K   122 downloads
and then covered everything in comic books :D I think the door cards are next.
I also fit a strip of hose pipe along the front edge before covering, it gives it an nice rounded edge, and i thought just incase i bang my head it's a bit softer than MDF.
Attached File  03-finished.jpg   75.57K   123 downloads
Attached File  04-finished.jpg   60.13K   58 downloads
and rather geekily made stickers for SD card albums.
Attached File  02-sd.jpg   58.33K   56 downloads
#2 Richie83
Richie83
  • 1,495 posts
Posted 18 July 2014 - 12:29 PM
Superb effort. How did you stick the comics? The radio looks great, and there's a little shelf above?
#3 jon_barnes77
jon_barnes77
  • 35 posts
Posted 18 July 2014 - 12:54 PM
cheers - yeah there's a shelf too. i had to put a lip on the shelf edge, otherwise everything flies of onto you when you drive.
I coated the roof with PVA and wallpaper lining, and then did that again. then PVA'd the comics on. they then had a couple coats of clear varnish - so it's kinda quite solid.
#4 TigersFanMatt
TigersFanMatt
  • Just Joined
  • 37 posts
Posted 18 July 2014 - 03:21 PM
Looks fantastic, i take it there is no sound proofing or anything behind the comics?
#5 jon_barnes77
jon_barnes77
  • 35 posts
Posted 18 July 2014 - 07:16 PM
I did think about lining it but there's little point. It'd still be a really loud car.
#6 splintercat
splintercat
  • 616 posts
Posted 18 July 2014 - 09:40 PM
absolutely love this idea bud ..................mite even av a go meself if you dont mind as i ate my lining and bean meaning to paint it/whatever for ages......
#7 jon_barnes77
jon_barnes77
  • 35 posts
Posted 21 July 2014 - 08:01 AM
yeah go for it. After i'd done this, i saw b&Q sold marvel wallpaper - would have saved me a load of effort if i'd just bought a roll of that - if that's the look you're after.
#8 Daviewonder
Daviewonder
    Needs an extra inch!!
  • 1,020 posts
Posted 21 July 2014 - 09:06 AM
That's MARVELlous ;-)
#9 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 21 July 2014 - 09:47 AM
Sigh theres always one.
#10 splintercat
splintercat
  • 616 posts
Posted 21 July 2014 - 06:57 PM
That's ironic AS I ACTUALLY work there...never thought about that I was gonna ask you what comics you used as I.ve just read that you have to use pictures from a laser printer as with some comics the print and ink will run ?
How did you get on with that ?
#11 jon_barnes77
jon_barnes77
  • 35 posts
Posted 21 July 2014 - 09:30 PM
Just used an inkjet on regular paper. It does bleed a little bit from the glue and varnish, found a load online from the golden age - 40s/50s, so the slight fuzziness suits it.
