Clock Problems
10 replies to this topic
#1 TheJack
TheJack
    Formally known as Jackocola
  • 531 posts
Posted 19 July 2014 - 08:13 PM
I have a problem with my clock set up, I have a 3 clock in my Mini (not a centre one) and it works perfectly until I switch my sidelights on, dip lights and full beam then it starts to have issues. Bascailly soon as I turn on any lights both indicators light up but not a full light just like dipped and the fuel and engine temp go straight up! Also the rev counter goes up and down. Also when I go to indicate the lights on the clock flash for the other side to if I was going right then it which flash left but outside it would flash on the right side. Please help!
#2 mk1leg
mk1leg
  • 9,343 posts
Posted 19 July 2014 - 08:24 PM
check the printed circut on the back of clocks
#3 TheJack
TheJack
  • 531 posts
Posted 19 July 2014 - 08:32 PM
I have done, I guess I'M looking for wear?
#4 mk1leg
mk1leg
  • 9,343 posts
Posted 21 July 2014 - 07:10 PM
check the bi metal controller on the back of clocks......
#5 TheJack
TheJack
  • 531 posts
Posted 21 July 2014 - 07:32 PM
What does that look like, sorry I'm not the smartest!  :shy:
#6 mk1leg
mk1leg
  • 9,343 posts
Posted 21 July 2014 - 07:45 PM
on the back of the clocks is a voltage stabliser......
http://www.minispare...px|Back to shop
#7 TheJack
TheJack
  • 531 posts
Posted 21 July 2014 - 08:10 PM
I don't have a centre clock as that says for centre clocks only, and if you mean for my clocks I haven't seen it behind it at all
#8 mk1leg
mk1leg
  • 9,343 posts
Posted 21 July 2014 - 09:49 PM
its also on the back of the other clocks unless your's is of 1995-2001then its a Jap set up
#9 TheJack
TheJack
  • 531 posts
Posted 21 July 2014 - 09:52 PM
I will have a look, mines a 1990, would it affect the guages even with the lights off because I only get the issue when the lights are on side, dip and full
#10 mk1leg
mk1leg
  • 9,343 posts
Posted 21 July 2014 - 10:22 PM
ah try the gismo on the passanger side inner wing attached to baulkhead back of rad.....long ally plate with a gold cylinder on it this has some thing to do with lights........might need replacing.....
#11 cal844
cal844
  • 9,648 posts
  • Local Club: TFMOC
Posted 21 July 2014 - 10:26 PM
You have a bad earth... Clean ALL earth points, however unrelated it may seem... Also give the multi plug a push in, it can work loose or be in the wrong way!!
