Not Starting But Have Fuel And Spark
Posted 20 July 2014 - 08:33 PM
Checked the spark plugs and pulled the fuel pipe of the float barrell,
Turning over fine, but absolutely nothing in terms of firing up.
Any ideas, it was starting and driving fine last week, and has just been sat for a few days so I can hardly see a compression problem?
Any ideas appreciated
Posted 20 July 2014 - 08:35 PM
Pour a thimble full of fuel down the carb, if it starts briefly you have a fuelling issue
Posted 20 July 2014 - 08:40 PM
Posted 20 July 2014 - 08:42 PM
Sticking float, blocked jet
Posted 20 July 2014 - 08:47 PM
Posted 20 July 2014 - 08:48 PM
Ok thanks, would the brake cleaner not have fired it a bit?
It probably should've, did you have the throttle open?
Posted 20 July 2014 - 09:00 PM
Posted 20 July 2014 - 09:01 PM
Posted 20 July 2014 - 09:29 PM
yea everything is standard, im not 100% sure what type of engine it is. i just know it seems a very similar set up to the minis i have had before. Sorry ill point out that the accelerator wasnt pressed, so when i was spraying it the throttle may not have been open
but would it not still let enough in to at least chug it? there is absolutely nothing from it
Posted 21 July 2014 - 12:06 AM
Brake cleaner may or may not burn well enough to use as a test. Over the years there have also been safety warnings about not burning brake cleaner so my advice is not to use it for this purpose. Try the thimble of gasoline down the carb throat instead.
The other possibility is that the float valve is not stuck closed... but stuck open which will allow too much fuel into the carb. Again, try the thimble of gas and then check the plugs to see if they are wet with fuel if it doesn't start.
Posted 21 July 2014 - 04:45 AM
Hehehe....we discussed this - brake cleaner in the UK isn't the toxic stuff that may be available in the US - whether it burns well enough to give good combustion remains to be seen.
As an aside, if you are stuck - Axe body spray will start a big diesel that's a bit sluggish starting.
Drop of petrol down the pipe would be the most logical thing in the first instance.
Posted 21 July 2014 - 09:02 AM
in the uk axe is called lynx and theyre on offer at asda at the moment
Posted 21 July 2014 - 09:40 AM
But have you checked for a spark? If it isn't a fuel issue then ignition is the next place to look!
Posted 21 July 2014 - 10:31 AM
Try easy start should at least have it firing
Posted 21 July 2014 - 12:05 PM
Yes, we have discussed it before. You will notice I only mentioned safety as a side note.
Many aerosol sprays can burn. However, with gasoline in the tank and since the engine was designed to burn gasoline that is what I would try.
