Front Wheel Play / Knock After Cone Change
5 replies to this topic
#1 TMW.Racing
TMW.Racing
  • 248 posts
Posted 21 July 2014 - 08:13 PM
Evening All,
Changed one of the front cones yesterday (doing the other one on Friday), went well but once I got everything reassembled, wheel back on and car on the deck I gave the wheel the usual 3 and 9 o'clock shake and felt a knock and a slight bit of play which I am pretty sure was not there before (although I can't be certain).
I had the top arm out but otherwise I did not remove anything else.
Will be having a good look at it on Friday so if anyone has any ideas or pointers etc. as to what this could be, all help is appreciated!
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 21 July 2014 - 08:20 PM
Try your track rod end. If not have a good look at the ball joints.
#3 TMW.Racing
TMW.Racing
  • 248 posts
Posted 21 July 2014 - 08:27 PM
I will be doing the ball joints on friday as one on the other side needs doing so will do the lot, not sure it is that though because when I found the other one knocking I checked that side & didn't hear anything... unless breaking the taper to get the top arm off has knackered it or course! Is that plausible?
#4 pickuptruck1994
pickuptruck1994
  • 366 posts
  • Local Club: Weston Mini Muckers
Posted 21 July 2014 - 08:29 PM
Check your top arm could have play it in now some grease has been taken out of it.
#5 TMW.Racing
TMW.Racing
  • 248 posts
Posted 21 July 2014 - 08:31 PM
must admit I hadn't thought of that! Will check that one, thanks!
#6 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 21 July 2014 - 09:12 PM
Check the ballpoint pin is properly seated back in the taper and torqued. And the TRE if you disturbed it.
